Those of you who have installed Synapze DT
Jdmdc5teg06
I received my Synapze DT last Thursday, uploaded the newest firmware, 27.05, and installed it that same night.
Since installing it, my uconnect sometimes goes crazy after I leave the truck off for more than 39 minutes. When I go back in the truck, turn it on, and the uconnect freezes momentarily and reboots itself and is fine for the remainder. Then if I park it for more than 30-45 minutes again, it’ll do the same thing after starting it.
Any of you guys experiencing this?
I also had a OTA update last week and not sure if it’s the update that’s causing these issues, which I’ve never had before, or the Synapze.
Mine has been trouble free. I would remove the Synapse DT and then see if the Uconnect problem your having goes away.
I've had mine installed for almost a month now with no Uconnect issues. I also had some warranty work done about 60 days ago, and the dealer performed the latest update at that time.
I did experience a weird tach issue one morning, but it only happened once and hasn't returned.
I'd try removing the Synapze DT for a day or so to see if the issue persists. That should help narrow down whether it's causing the problem.
On a side note: I also read somewhere that a new Synapze update is in the works and should be released pretty soon.
I've had mine for about a month but am still on v.04 and experience no issues. I will wait for a (measurable) update with v.06 before I update
Thanks guys! I don’t drive the truck daily as I have a work car but I will uninstall the Synapze tonight when I get home and try driving it around to see. Hopefully it’s the Synapze and not my actual uconnect. And if it’s the Synapze, hopefully the upcoming firmware fixes it. I’ll report back here within a day or two in case anyone experiences the same issue.
HUGE Sale on Method Raised Wheels Exoctic Innovations New to the rho 2026 RAM RHO Order/Schedule/Build Thread Hello from ATX Eibach Pro-Lift Kit Installed
