Thoughts on AFE charge pipes?
On the truck yes, obviously not like you've got a big single turbo with no filter on it spool noise..but increased yes.
The Charger Inlet is a bit different, honestly the RHO one seems like a much smoother design, so we were really hoping for a HUGE increase in noise on the charger.
the charger is currently somewhere that I can't disclose verifying some really cool parts that will be released for both platforms(RHO and Charger) Soon, otherwise i'd try to get a video.
Nice, Glad to hear more parts in the works!! I genuinely think theres enough of a market out there between all the HO and SO motors out there.
Funny u mentioned porting. I took the Y off again today cuz i wasn’t happy w the one hot charge pipe ( shorter one) interior weld. I took a carbide burr to the charge pipe interior clumpy weld and a dremel to the plastic Y. It’s molded plastic and if u run ur hand in there u feel all the sharp edges and shit. I just smoothed them both out. It’ll have to do until we get more aftermarket stuff.
I did the exact same, need to get a new bit though and finish it
Put mine on yesterday, hot pipes only for now, definite increase in part throttle spool sound
Nice, curious did you guys notice any differences after doing so?
Back when we did saturn stuff there was basically no aftermarket so we were reduced to porting out oem parts sometimes, and it always did make a difference, small maybe, but not nothing.
i never put in on before, the smaller hot pipe has one welded joint and the inside had a lot of weld spatter, just smoothed it out a little
Ahh sorry I misunderstood / wasnt being very clear there, I thought you also ported out the weird intake Y as well, but you meant just the hot pipe right?
But any noticeable difference other than sound on the hot pipes?
yes correct, i didn't touch the y
not that i can tell, realistically they won't net much power if anything. even if they give 5 hp, are you really feeling that difference in a big heavy pickup truck?
Gotcha
Yeah very true probably not, but you cant blame me for hoping its this amazing difference lol
Yea def ain’t gonna feel anything crazy. Just peace of mind knowing airflow is supposed to flow smooth and not hit a bunch of imperfections. For me anyway.
Just had an oil change done and they noticed my cold charge pipe was wet. Has anyone had this issue before? truck drives great and no check engine or warning light. Still doing 4.5s 0-60 with lift and 37s...so not affecting performance. I'm thinking it could just be a super small boost leak at the connection and that I will need to replace the seal or coupler.
Just had an oil change done and they noticed my cold charge pipe was wet. Has anyone had this issue before? truck drives great and no check engine or warning light. Still doing 4.5s 0-60 with lift and 37s...so not affecting performance. I'm thinking it could just be a super small boost leak at the connection and that I will need to replace the seal or coupler. View attachment 36233
someone else on here had this issue, i remember seeing it, but cannot find where
yeah, I tried searching too but couldn't find it so I figured I would post it here.
I did the same, wasn't stoked on that.
I put on the MBRP.. Fucking sucked .. Way too Loud in the Cab. Great cold start and exterior sound, but unbearable on the highway. Switched to the AWE OFG, and its super loud exterior, but quiet in the can on the highway! (until you get on it)
I took my truck in last week for an oil change and tech noticed I had oil residue present on the charge pipe as well. They ended up ordering a new charge pipe. No truck for 5 days. We’ll see if it comes back…
FWIW when I was doing my intake I took off the other pipes to give them a quick port job, my rho has like 400 miles on it, this seemed like alot of oil just sitting there...just quickly thinking, with these leak complaints and what I just found, is that something a catch can would help with? Apparently we all have pretty active pcv systems and very thin oil
Yes this is why we preach catch cans from Day 1 on these!
J&L is a simple install and cost effective.
What did you do to your RHO Today? I don't want air bags -- how about Timbren? What did you do to your RHO Today? 2026 RHO New Wheels & Tires RAM RHO Canyon Lake Photo Thread RAM 1500 RHO 40in LED Light Bar PRO Easy Install
