- Jul 8, 2024
- 1,009
- Media
- 95
- 1,797
- 23 Ram 1500 Limited
- Military
- USN
-18 offset would not look goofy, it looks great. Literally nothing wrong with some poke. My bronco setup is -48 offset, she looks great!You neglected to mention the offset in your first post where you mentioned your concern was the offset. In your last post you mentioned -18 which I think would look goofy because they would be sitting out an inch and a half from where they are from the factory. Nothing sillier looking than a widebody truck with the wheels still sticking out farther than the fender. Very likely to rub with the -18. Guaranteed to rub if you put 37s on it with those wheels.
Beautiful-18 offset would not look goofy, it looks great. Literally nothing wrong with some poke. My bronco setup is -48 offset, she looks great!
Thank you!Beautiful![]()
Doesnt this mess with the speedometer and trans calibration. IS the tire the same OD?I also did the front level and didn't touch the back looks pretty level to me. Going with 20x10, -18 on 37s.
Why yes it does haha about 5mph difference in what is shown in speedometerDoesnt this mess with the speedometer and trans calibration. IS the tire the same OD?
It would only be a 5 mph difference at 100 mph. You would be going 5% faster than your indicated speed.Why yes it does haha about 5mph difference in what is shown in speedometer
This will be my setup once it arrives, Please post some pic once it's doneI also did the front level and didn't touch the back looks pretty level to me. Going with 20x10, -18 on 37s.
Will doIf you do, and you don’t use the top shim plate I’d buy it off of you.
I vote 37s on 20in wheels. Color is up to you. But, that IGM video guy (I’m the first ever at doing anything to my truck) used Rogue and had to remove the spare tire to get it level. They don’t tell you that in the video. You shouldn’t have a problem with positive offset.I ordered a white RHO & while waiting I’m trying to figure out what size wheels & tires will work with or without a level, wheel color etc…any suggestions thoughts etc…would be greatly appreciated! If a level is needed I would only want to use the rogue perch I like a slight rake and I like more tire in the wheel well.
Last has anyone had issues when leveled with the auto driving feature?
Current Debate
HFX-1 Bronze or Gunmetal?
18x9 0 offset with 35x12.5 - I know I won’t need a level for this but not sure if it’s enough tire.
20x9 +15 37x12.5 level needed?
20x9 +15 325/60 level needed?
He’s not going for level. Like he said he wants a little bit of rake. Rogue kit will be perfect. Myself I just wanna slightly reduce it also. That’s why I offered to buy his upper shims.I vote 37s on 20in wheels. Color is up to you. But, that IGM video guy (I’m the first ever at doing anything to my truck) used Rogue and had to remove the spare tire to get it level. They don’t tell you that in the video. You shouldn’t have a problem with positive offset.
Correct. I only added that bit as I haven’t found 37s under rogue without the top shim, in the event 37s are selected of course.He’s not going for level. Like he said he wants a little bit of rake. Rogue kit will be perfect. Myself I just wanna slightly reduce it also. That’s why I offered to buy his upper shims.
The 18 inch ones are offered in 0!I love Vossen wheels but wish they came in a closer offset to 0. Personally think -18 is to much poke.
I love Vossen wheels but wish they came in a closer offset to 0 without customizing. Personally think -18 is to much poke.
