Did you install the little plastic pieces to secure the mat? I’m thinking to not do it, one because it won’t stick properly to the bedliner, but two because I have a tonneau cover. Seems like overkill.
I did not install them, for the exact same reasons as you. May try just sticking them to the spray in bedliner if I get around to it.
Today I traded in my RHO. Had a 26 Level 1 in white. I decided to take advantage of the crazy deals RAM has going on right now and got a Level 2 Rebel in Tank Green. Between the dealer discount and the RAM rebates, I got $20,600 off MSRP. New truck is great and I love the color. I generally get a new truck every 2-3 years so I'll enjoy this one while looking into the next one (the Rumble Bee probably). Cheers to the great info everyone brings to this forum. See y'all on the next one.
Today I traded in my RHO. Had a 26 Level 1 in white. I decided to take advantage of the crazy deals RAM has going on right now and got a Level 2 Rebel in Tank Green. Between the dealer discount and the RAM rebates, I got $20,600 off MSRP. New truck is great and I love the color. I generally get a new truck every 2-3 years so I'll enjoy this one while looking into the next one (the Rumble Bee probably). Cheers to the great info everyone brings to this forum. See y'all on the next one. View attachment 32727
Ok
Wow thats crazy deal! What engine does it have? How does it ride compared to the RHO?
Picked this level 1 up a few weeks ago. Added ark mini's, ceramic plus tint, mx4, matte screen protector, feynlab ceramic coating, and got a cat6 sitting on the bar.
Debating doing a break in oil change next week and installing the cat after or just doing it tomorrow and letting it ride at the dealership for my routine service appointments.
ceramic tint 25% front windows and 35% windshield Happy I didn’t go darker.
How does the 25% ceramic tint look compared to the stock rear windows? Lighter, darker, or same? Hard to tell from your pics.
I got 20% on the fronts and they are just a shade darker. Hard to really tell except from the inside.
Added the weathertech bed mat. Easily better than the lasfit liner. I kept the lasfit tailgate mat. WT mat was pricey but worth every dollar.
I had this weathertech bed mat in a GMC I used to own since it didn’t have bedliner sprayed in. The mat worked in protecting the bed but it trapped a lot of water and grit under it - and it blew out onto the highway once even though it was attached with the supplied fasteners.
About the same. But dark enough so that you can’t see in light enough to see at night
Fabricated new lower mounts for my Airlifter airbags to clear my Eibach sway bar. Rides and handles very well. Running air bags at 6 psi. Rear is 3/4 up from front with Eibach 1.6” front springs
what are those sway bar mounts???
What did I use? Eibach bar comes with mounts no bolts. The aluminum spacer block is a 1 inch spacer block. It was 20 bucks. It says it’s for a Toyota, but I figured the bolt spacing would work and it did. The reason for the spacer block is to keep the swaybar from hitting the spring perch on the axle at full droop. This way bar links are 15 1/4 inch core 4 x 4 with the Johnny joint in the bottom.
interesting, I like that better than the u-bolt the hellwig uses
MBRP & MRT Exhaust 10% Off All month Long! 2026 RAM RHO Order/Schedule/Build Thread $150 off BAK MX4 Tonneau Covers | $200 off Revolver X4s / Xts | Up to $400 off Powered Tonneau Covers | Ends 4/30/26 @ JustBoltOns.com Leveling kit What did you do to your RHO Today? Hyper milaging a RHO, Ha
