- Oct 12, 2026
- 19
- 0
Technical Service Bulletin · TSB 08-305-26
Published: Aug 1, 2026
Applies to: Ram 1500 (2025 model year)
Summary (official text)
Flash: Brake System Control Module (BSCM) Updates **Customers may experience one or more of the following: SYMPTOM: ● Warning message "Selec-Speed Unavailable" appears in the Instrument Panel Cluster (IPC) when trying to enable the Selec-Speed Control (SSC) function. NOTE: There will be no Diagnostic Trouble Codes (DTCs) and no driveability concerns with this symptom.** ● Anti-Lock Brake System (ABS), Electronic Stability Control (ESC) and 'Decel ACC' lights on in the IPC. Technicians may also find the following: ● DTC C121A-00 - Steering Angle Sensor Not Initialized - Is stored with no Malfunction Indicator Lamp (MIL). This bulletin involves reprogramming the BSCM with the latest available software.
Sources
- 08-305-26 (PDF, NHTSA document 11035978) — Aug 1, 2026
