- Oct 12, 2026
- 22
- 0
Technical Service Bulletin · TSB 18-079-26
Published: Oct 7, 2026
Applies to: Ram 1500 (2025 model year)
Details from NHTSA as of Oct 17, 2026. If NHTSA or Ram revises this notice, this post is updated and significant changes are noted in a reply. The linked documents are the authority, and a dealer can confirm whether it applies to your VIN.
Summary (official text)
Flash: Powertrain Control Module (PCM) Update Customers may experience a Malfunction Indicator Lamp (MIL) illumination, and the vehicle may exhibit SYMPTOM: or set one or more of the following Diagnostic Trouble Codes (DTCs): ● P0300-00 - Multiple Cylinder Misfire - in Active or Stored status set during cold start catalyst heating. ● P0301-00 - Cylinder 1 Misfire - in Active or Stored status set during cold start catalyst heating. ● P0302-00 - Cylinder 2 Misfire - in Active or Stored status set during cold start catalyst heating. ● P0303-00 - Cylinder 3 Misfire - in Active or Stored status set during cold start catalyst heating. ● P0304-00 - Cylinder 4 Misfire - in Active or Stored status set during cold start catalyst heating. ● P0305-00 - Cylinder 5 Misfire - in Active or Stored status set during cold start catalyst heating. ● P0306-00 - Cylinder 6 Misfire - in Active or Stored status set during cold start catalyst heating. Customers may also comment on one or more of the following: ● Vehicle has a rough idle. ● Engine has a miss. ● Noisy valvetrain. This bulletin involves inspecting the PCM software level and, if necessary, reprogramming the PCM with the latest available software.
Sources
- 18-079-26 (PDF, NHTSA document 11038499) — Oct 7, 2026
- 18-079-26 (PDF, NHTSA document 11038536) — Oct 7, 2026
