TSB 2025 Ram 1500 Powertrain Control Module (PCM) Updates — 18-077-26
Technical Service Bulletins
Imported from NHTSA data · last checked Oct 12, 2026
RamRHOForum
Forum Support 🛠️
Technical Service Bulletin · TSB 18-077-26
Published: Aug 19, 2026
Applies to: Ram 1500 (2025 model year)
Summary (official text)​
Flash: Powertrain Control Module (PCM) Updates Customers may experience a Malfunction Indicator Lamp (MIL) illumination and the vehicle may SYMPTOM: exhibit/set the following Diagnostic Trouble Code (DTC): ● P0300 - Multiple Cylinder Misfire. Customers may experience one of the following: ● Vehicle runs rough on initial cold start only after an overnight or extended soak. **This bulletin involves reprogramming the PCM with the latest available software.**
Sources​
  • 18-077-26 (PDF, NHTSA document 11036359) — Aug 19, 2026
Ceramic Coating - Need Opinions Window Vent Visors/Deflectors Tape-On or In-Channel new baybay 🔥 First look at Serrano Green SOUTHWEST ROADTRIP Eibach 1.6 vs 2.7 front only
