TSB 2026–2027 Ram 1500 R1H U43.17 Software Update - FOTA — 08-372-26
Technical Service Bulletins
Imported from NHTSA data · last checked Nov 10, 2026
RamRHOForum
Forum Support 🛠️
Technical Service Bulletin · TSB 08-372-26
Published: Oct 9, 2026
Applies to: Ram 1500 (2026–2027 model years)
Summary (official text)​
R1H U43.17 Software Update - FOTA Customers may experience one or more of the following: SYMPTOM: ● Screen Freeze or Radio Reset. ● Projection will not reconnect. ● Audio or music skipping and/or cutting out during playback. ● Apple CarPlay®/Android Auto® improvements: fixes for disconnections, freezes, screen distortion, and pairing issues. ● "Service Air Suspension System" message displayed when the Up or Down button becomes stuck. ● Trailer Surround Camera dimensions not retained after an ignition cycle. ● Distorted radio startup animation. ● Home screen media widget does not display the artist name. ● Turn signal blind spot view does not turn off after the turn is completed. ● Vehicle Settings page becomes frozen and unresponsive to touch input. ● "AUTO" Drive Mode takes several seconds to update after the mode is changed. ● Screen display size changes from normal to small without user input. ● Radio text displays in English when Portuguese is selected. ● Screen flickers, resets, or goes blank while driving. ● Steering wheel volume adjustment causes screen distortion. ● Surround Camera View guidelines remain visible when the setting is turned off in the radio. ● User is able to add a device to the head unit while the vehicle is in motion. ● Radio Bluetooth is unable to discover a phone even when the phone is directly in front of the radio. ● App screen turns completely black while driving. ● Phantom chimes occur without any warning messages or notifications. ● Left-side blind spot turn signal camera has a longer activation delay than the right-side camera. ● Radio switches to Android Auto® unexpectedly and displays a black screen. ● Phone cannot be reconnected to Bluetooth after being deleted. ● Glovebox and Apps text overlap on the MyCar or Performance Pages screen when the glovebox button is pressed. In addition, the following software enhancement is included: ● Remove Virtual Wall option from the Vehicle Settings menu.
Sources​
  • 08-372-26 (PDF, NHTSA document 11038493) — Oct 9, 2026
  • 08-372-26 (PDF, NHTSA document 11038530) — Oct 9, 2026
Details from NHTSA as of Oct 17, 2026. If NHTSA or Ram revises this notice, this post is updated and significant changes are noted in a reply. The linked documents are the authority, and a dealer can confirm whether it applies to your VIN.
I’ve suddenly started having a lot of problems connecting to CarPlay. I’ve read that an update may fix the issues
Have you tried a hard reboot? Press the volume and search knobs at the same time until the screen goes black. Ignition is in on position.
i haven’t. I’m going to try it in a little bit. Thanks. I appreciate it.
If you're still on version 42 that may be a temporary fix, although an easy one. You may have to do it again from time to time until you get the version 43 update which in my case fixed it for good.
I am. Hopefully the update will work when I get it. Did you do it yet?
I did. That's the one that took numerous tries to complete but it fixed everything for good.
Unfortunately it did not fix mine for good. When it disconnects or fails to connect from the start, if I try to manually click the CarPlay to connect (in the source screen I think it is) on the uconnect, nothing happens and it just says make sure car play is on and in range or something of that nature.
With them pushing out updates though, I have faith one of these will fix it for everyone at some point
Sorry to hear that. Make sure you're on uConnect ver 43, not 42. Also make sure your iPhone has the latest ios version. If those line up, try just holding the volume (left) button in with the engine running until the screen turns black. After the screen comes back, stop the engine, open and close the door, and restart. That should solve the problem. If not you probably have something more serious going on which is above my pay grade.
Yea unfortunately I have tried all the above, and no cigar!
Thanks for the suggestions, I'm still hopeful that one of these OTAs will address it for everyone.
2026 RAM RHO Order/Schedule/Build Thread Spare Tire Oil Analysis Silver ppf & tint What did you do to your RHO Today? Quality is not job 1.
