2026–2027 Ram 1500 Software Update — U43.17
Imported from NHTSA data · last checked Oct 12, 2026
RamRHOForum
Forum Support 🛠️
Over-the-air software update · U43.17
This is an over-the-air software update notice. Ram filed it with NHTSA to describe a software release; it is not a recall unless it says so. Delivery depends on your truck's connectivity and settings.
Published: Sep 8, 2026
Applies to: Ram 1500 (2026–2027 model years)
Summary (official text)​
Radio Over The Air Update to U43.17 R1H Software Version (FOTA) Customers may experience one or more of the following:- Navigation Stability - Android Auto & Carplay stability & connectivity- Air suspension- Trailer Tow pages- Power management app- Distorted/glitchy display prior to start‑up animation- Text appearance display- Widget incorrect display- Turn signal blind spot response timing- Audio cut out - Drive Modes selection- Park assist Guidelines selctio
Sources​
  • OTHERDOC_175 (PDF, NHTSA document 11037366) — Sep 8, 2026
Has this update reached your truck? Share your model year and anything that changed after it installed.
Ceramic Coating - Need Opinions Window Vent Visors/Deflectors Tape-On or In-Channel new baybay 🔥 First look at Serrano Green SOUTHWEST ROADTRIP Eibach 1.6 vs 2.7 front only
