- Oct 12, 2026
- 19
- 0
Technical Service Bulletin · TSB 05-003-26
Published: Aug 14, 2026
Applies to: Ram 1500 (2026 model year)
Summary (official text)
Brake Fluid Leak At The Brake System Control Module 2 (BSCM2) The customer may comment the following: SYMPTOM: ● Drops of brake fluid are on the ground. This bulletin involves tightening two BSCM2 brake line fittings.
Sources
- 05-003-26 (PDF, NHTSA document 11036267) — Aug 14, 2026
