TSB 2026 Ram 1500 Electronic Shift Module (ESM) Updates — 08-308-26
Technical Service Bulletins
Imported from NHTSA data · last checked Oct 12, 2026
RamRHOForum
Forum Support 🛠️
Technical Service Bulletin · TSB 08-308-26
Published: Aug 6, 2026
Applies to: Ram 1500 (2026 model year)
Summary (official text)​
Flash: Electronic Shift Module (ESM) Updates Customers may comment on one or more of the following: SYMPTOM: ● Shifter is unresponsive. ● Unable to start the vehicle. ● “Service Shifter” message displayed in the Instrument Panel Cluster (IPC). This bulletin involves inspecting and possibly reprogramming the ESM with the latest available software.
Sources​
  • 08-308-26 (PDF, NHTSA document 11036154) — Aug 6, 2026
Ceramic Coating - Need Opinions Window Vent Visors/Deflectors Tape-On or In-Channel new baybay 🔥 First look at Serrano Green SOUTHWEST ROADTRIP Eibach 1.6 vs 2.7 front only
