TSB 2026 Ram 1500 Transmission Rattle — 21-062-26
Technical Service Bulletins
Imported from NHTSA data · last checked Oct 12, 2026
RamRHOForum
Forum Support 🛠️
Technical Service Bulletin · TSB 21-062-26
Published: Sep 25, 2026
Applies to: Ram 1500 (2026 model year)
Summary (official text)​
Transmission Rattle Customers may comment on the following: SYMPTOM: ● Rattle noise coming from the transmission. This bulletin involves inspecting and possibly tightening the transmission oil heater mounting nuts to proper specification.
Sources​
  • 21-062-26 (PDF, NHTSA document 11037573) — Sep 25, 2026
Ceramic Coating - Need Opinions Window Vent Visors/Deflectors Tape-On or In-Channel new baybay 🔥 First look at Serrano Green SOUTHWEST ROADTRIP Eibach 1.6 vs 2.7 front only
