TSB 2026 Ram 1500 Wrong Instrument Panel Cluster (IPC) Configuration — 08-328-26
Technical Service Bulletins
Imported from NHTSA data · last checked Oct 12, 2026
RamRHOForum
Forum Support 🛠️
Technical Service Bulletin · TSB 08-328-26
Published: Sep 3, 2026
Applies to: Ram 1500 (2026 model year)
Summary (official text)​
Wrong Instrument Panel Cluster (IPC) Configuration Customers may comment on one or more the following: ● Oil pressure gauge and battery life gauges are blank or missing from the IPC Fig. 1. ● The Trailer Brake radial slider movement will not move past one bar and is inaccurate Fig. 2. NOTE: The Trailer Brake percentage does display correctly. This bulletin supersedes Technical Service Bulletin (TSB) 08-328-26, date of issue September 03, 2026,which should be removed from your files. All revisions are highlighted with **asterisks** and includean updated LOP. This Technical Service Bulletin (TSB) has also been released as a Rapid Service Update (RSU) 26-164, date of issue September 03, 2026. All applicable RSU VINs have been loaded. To verify this RSU service action is applicable to the vehicle, use VIP or perform a VIN search in DealerCONNECT/ServiceLibrary. All repairs are reimbursable within the provisions of warranty.
Sources​
Ceramic Coating - Need Opinions Window Vent Visors/Deflectors Tape-On or In-Channel new baybay 🔥 First look at Serrano Green SOUTHWEST ROADTRIP Eibach 1.6 vs 2.7 front only
