- Oct 12, 2026
- 19
- 0
Technical Service Bulletin · TSB 18-078-26
Published: Sep 26, 2026
Applies to: Ram 1500 (2027 model year)
Summary (official text)
Flash: Powertrain Control Module (PCM) Updates Customers must experience a Malfunction Indicator Lamp (MIL) illumination and the vehicle must SYMPTOM: exhibit/set one or more of the following Diagnostic Trouble Codes (DTCs): ● P05CC-00 - Cold Start A Camshaft Position Timing Performance Bank 1. ● P05CE-00 - Cold Start B Camshaft Position Timing Performance Bank 1. This bulletin involves inspecting and possibly reprogramming the PCM with the latest available software.
Sources
- 18-078-26 (PDF, NHTSA document 11037571) — Sep 26, 2026
