That magic box 2.0 actually work? I thought that was some IG advertising BS lolSick Diesel has some cool stuff too. I will probably add the top grill light that connects the two sides. Will have to see though after I get the truck and see
And use my Magic Box 2.0 so we can watch TV on road trips on that center screen. Don't need a switch for this, but wouldn't mind mounting it down low somewhere and try to hide it (tuck and hide USB-C line).
I thought it was illegal to have rear-facing amber lights. As I recall, amber lights can only face forward or to the side, and any rear-facing lights had to be red (except for emergency vehicles).Took me a bit to dig out that wireharness from under the fuse box - lots of tape and low gauge (stiff) wire. But worked like a champ with with the M&R reverse kit. Install easy, mounting is perfect - tucks the lights up close to the bumper. Aux Switch 1 - bright white LED - Aux Switch 2 - amber LED.
well interesting - learn something new every day .... ill be honest never checked laws etc .... the lights came "set up" for white/amber or white/red (you select the alternate LED color at order).I thought it was illegal to have rear-facing amber lights. As I recall, amber lights can only face forward or to the side, and any rear-facing lights had to be red (except for emergency vehicles).
They might be illegal to have turned on when you’re running down the highway, but no cop is going to care otherwise.well interesting - learn something new every day .... ill be honest never checked laws etc .... the lights came "set up" for white/amber or white/red (you select the alternate LED color at order).
One wire lead when hot/on lights up the white (which I wired to Aux1) and the other lead when hot/on lights up the amber (which went to aux 2). I only use them at night when loading the bed, camping etc. The amber is kinda nice at a camp sight when you want to illuminate the ground but not blind other folks. Never when driving (except the occasional backup).
The amber lead doesnt need to be powered ... so guess I would just disconnect if I ever got "caught".
I run the Strands Siberia Qube, very nice stuff.I pre-ordered the M&R 23" pro light bar so that's 2 of my aux switches when it gets here. I'm looking for the best ditch lights now. I want a set with the amber drl feature.
M&R has those too. They're pretty nice.I pre-ordered the M&R 23" pro light bar so that's 2 of my aux switches when it gets here. I'm looking for the best ditch lights now. I want a set with the amber drl feature.
OK. Thanks!M&R has those too. They're pretty nice.
Did you use their harness or in the cab switches?I run the Strands Siberia Qube, very nice stuff.
If you wanna pick some up, here is a link & discount code!
Use this link to shop - https://strandsamerica.com/?ref=swift1
Use MIKEYSWIFT to save 15%
I used their harness to make a custom one big enough for the engine bay. Ran everything up to the corner by the fuse box, under there are the wires for the Aux switches. They are already fused and relayed. Connected the hot wires to the pink Aux wires, and grounded everything to one of the 4 posts up the side of the engine bay.Did you use their harness or in the cab switches?
Thanks boss! That's how I wired my front light, but you need two switches to run the amber running light or the main light. Unless, like you said, you have them switch on with the ignition.I used their harness to make a custom one big enough for the engine bay. Ran everything up to the corner by the fuse box, under there are the wires for the Aux switches. They are already fused and relayed. Connected the hot wires to the pink Aux wires, and grounded everything to one of the 4 posts up the side of the engine bay.
In the Uconnect settings for those switches, you can choose to have them switched with ignition or latched, and/or set to remember last state.
I have all Amber position lights set to Switch 1, light bar to Switch 2, and ditch lights to Switch 3.Thanks boss! That's how I wired my front light, but you need two switches to run the amber running light or the main light. Unless, like you said, you have them switch on with the ignition.
Baja designs or nothing!!…… peasants!I run the Strands Siberia Qube, very nice stuff.
did you run multiple amber backlit lights to aux 1 or just have one? Im debating getting amber backlit bar and might get 2x lp6 with amber as well so was seeing if both could be ran to one aux. hit aux one for all amber backlit lights.....I have all Amber position lights set to Switch 1, light bar to Switch 2, and ditch lights to Switch 3.
Switches 1 & 4 are 50 amp, 2 & 3 are 20 amp.
Yes I ran all the amber lights to one switch.did you run multiple amber backlit lights to aux 1 or just have one? Im debating getting amber backlit bar and might get 2x lp6 with amber as well so was seeing if both could be ran to one aux. hit aux one for all amber backlit lights.....
Baja designs or nothing!!…… peasants!![]()
I need to swap out the fog lights tooAll 4 aux switches have been utilized with just about every non LP flavor of Baja Designs lightingView attachment 23360View attachment 23358View attachment 23357
