Cat 6 Install
If I see a White Rho with Texas plates speeding I will let you know !
Thanks!!! She should be past Texarkana by now. Its RHO badge is red n white. Miami Vice style. 🤣
Just installed the CAT6 and WOW my mind is blown at how much different the truck drives!🤯 Totally woke up the engine, Im running 37's and this thing is so fast. Im running into an issue where it's not shifting into 2nd at WOT. Just hits the limiter until I let off the throttle. Haven't tinkered with the app much yet but is anyone else running into this? I did the eibach 2.7"/1.5" Pro Lift and skipped the ride height sensors, could this be part of my issue?
Yep. Need the Zona ride height adjustment pieces then you’ll be gtg
After waiting 5k miles I finally pulled the trigger today and bought a Cat 6 (great deal from @Nick797 ). Do they include a decent installation video or is there a better video out there to use?
Installed mine today ! question do i need to change the spark pugs?
Also thanks again guys at 797 performance.
Just plug it in, set it up and mash that pedal and enjoy 😂
It's as simple as it gets.
Sounds good thank you. Did you use the Diablosport video for install?
I did. It was good except for the MAP sensor connection. I just removed the sensor with a torx bit to get better access to it and screwed it back in snugly.
I’m trying to take the harness off for some warranty work. I have been wrestling with the MAP sensor for an hour but it won’t budge. Any tips?
i find it easier to just remove the whole sensor then disconnect. Just don’t lose the screw.
I never lock em down(except the main harness) so it makes easier to disconnect.
I use a small archery pick to unlock them. Made it super easy.
What did you do to your RHO Today? Hood not aligned JANUARY order updates! Long time lurker What did you do to your RHO Today? New member from South Florida
