Dead battery this morning… thankful for jump pack…. Software issue that causes this.
Jrock
Range Rover 2016
Audi S5 Sportback 2019
I have about 12k miles of issue free driving on my 2025, which I received in May of 2025. I have tickle charged my battery multiple times after reading all of the issues. I have all of the proximity settings turned off etc. and this morning battery was dead. Since I do take my truck into remote places and knowing of this issue with these, I had purchased a jump pack. Hooked up the jump pack, pressed the boost button, waited for literally 2 minutes and the truck came to life and it cranked right over. After cranking pack still had a 92% charge left. Definitely recommend keeping something like this in the truck, fits perfect in the storage containers on the rear floorboard.
In doing some research it looks like two known issues for this…
TSB 08-140-26 Rev. A (April 2026): Addresses excessive battery drain involving the Radio Frequency Hub Module and proximity detection. A software update is available for applicable vehicles equipped with proximity approach/departure lamps.
TSB 18-060-26 (June 2026): Documents a PCM-related issue where the front axle disconnect can repeatedly activate while the truck is off, eventually depleting the battery. The bulletin described a software fix under development; the dealer should check its current status.
Good idea. I carry a jump pack in all my vehicles. Used my NOCO Boost GBX55 to help a mom with kid jump start her minivan just last week. Sometimes, you are someone else's good luck charm :)
I bought the GooLoo on Amazon last night after reading your post. Doesn't hurt to keep it in the truck!
Battery will not take a charge… off to the dealer in the morning..
DM us with the above details. We'd like to look into this for extended options of support that may be available to you.
Chris,
Ram Cares
Quick update: Got the RHO back from the dealer. They deep-cycle charged and tested both batteries and stated they are healthy.
They applied PCM software update RSU 26-138, updating the PCM from 68641784AE to 68641784AI.
This is associated with TSB 18-071-26 Rev. B, which supersedes the earlier battery-drain bulletin 18-060-26. The update addresses an issue where the drivetrain control module can repeatedly wake up while the truck is off, draining the battery.
The dealer also stated they addressed the radio/proximity module issue, although I haven’t confirmed that update on my paperwork.
I still have an open case with Ram Care. For now, I’ll monitor the truck without trickle charging and keep my jump pack handy.
If you’re experiencing battery drain, ask your dealer to check RSU 26-138 and RFHM bulletin 08-140-26 Rev. A.
Hopefully this resolves it. I’ll update the thread if the problem returns.
Wife bought a Povasee jump starter and didn't tell me.
I am set!
What did you do to your RHO Today? I don't want air bags -- how about Timbren? What did you do to your RHO Today? 2026 RHO New Wheels & Tires RAM RHO Canyon Lake Photo Thread RAM 1500 RHO 40in LED Light Bar PRO Easy Install
