You got the Bluetooth nutis there no nut there to unscrew for the rho? I changed my oil and spilled a bit when filling. Trying to take the cover off so I can clean it up. Should I just yank up?
That is the well of the engine cover. There’s no nutThere’s a 13mm nut that sits in a well in the middle of the cover near the back ( toward the cab/firewall). You’ll have to get up on the front and use a long socket extension to get it. Once loosened you can unscrew it with your hand. The cover then lifts off with a little effort. There are two prongs at the front of the cover and one that slots into a hole near the firewall.
To reinstall so the opposite starting with locating the rear prong into the receptacle near the firewall, then locating the other two near the front (radiator). Push down and they click back into place. Screw the bolt back in.
Good luck!
Sorry. I’m not describing it well. I’ll take a picture. It’s behind the ribs. I can’t describe Bette than that.That is the well of the engine cover. There’s no nut. Or I’m just blind
Thank you. I know exactly where that is.Sorry. I’m not describing it well. I’ll take a picture. It’s behind the ribs. I can’t describe Bette than that.
Same pic you posted, you have no nut for some reason.Thank you. I know exactly where that is.![]()
