New Tires/Wheels - TPMS Question
tlh235
Jeep Wrangler 392
Air Force
So i ordered my wheels/tires from customoffsets...they came with TPMS installed. I then had my local shop mount the new wheels/tires onto the truck and they seemed to have issues syncing up the TPMS. Something about the couple machines they have on hand aren't working with this particular set of TPMS. Does this sound right and if so, any ideas on what tool would work?
Sensor Type: MXSensor 1
Same issue on my '24 Wagoneer with sensors from tirerack, had to buy the mopar sensors and have the dealer swap them out. It was under 200 if i remember right.
so your only option was to buy new tpms. thats nuts. how are they making new tpms that tools can't read. ugh.
Tirerack sensors
433MHz Tire Pressure Sensor
Vendor Part #: 3996-100
Those didn't work
They put in 68591921AB-001 at the dealer and those did work
I thought the sensors actually sync up after 30 or so miles of driving? Obviously they need to be the correct sensors.
yeh, they didn't auto update so i took it back to the shop and they said the 2 tools they had wouldn't work on the TPMS that were installed.
Just an FYI, the Mopar sensors sync up immediately with the truck. I purchased new wheels and the OEM sensors from Nick at 797 performance. They are in fact 433 MHz but I have heard of issues with aftermarket sensors. You should definitely hit up Nick if you need the OEM’s.
@Nick797 can you shoot me a link for these? I didn't find them on the website (just Ford ones).
I can verify that Mopar TPMS part # for the 2025 RHO is 68293199AA
These will work with any Ram 1500 from 2022- 2025 TRX and RHO included
To the OP
I've had a TON of issues using custom offsets universal sensors. We usually only use MOPAR or Schrader, unfortunately when they do not focus on a specific platform you'll run into something like this. :( We can get a set of OE out for you asap!
I just reinstalled the mopar sensors that was made for my truck and after 60 miles, still have not paired to the truck, this is the 2nd set now after the 1st set was Amazon's bs, but now I bought the ones from mopar, still not working. Any tips
Aux Battery Swap for H8 Main Battery What did you do to your RHO Today? First look at Serrano Green Does anyone know what this is? NEW MEMEBER 2026 Ram announcements a 825hp TRX SRT Truck? Mustang Legend over 1000hp? Industry updates NEW CEO
