I just picked mine back up for the purge valve recall, and asked them to check for other software recall / TSB updates. My truck received the following, without much description as to what these were for:
Recall B4C - Cluster Softwaree
Recall RRT - 25-197
Recall RRT - 25-237
Recall RRT - 25-239
I’d like to research what each of these did. I can see the cluster reset most of my settings, so clearly that took an update. Also, when I went to leave the lot my truck surged forward when I touched the gas pedal. Clearly there is some different tune on the throttle response at a minimum. I’ll be curious to see if that also improved my shift points in Auto mode.
I did also do a quick check, and I didn’t see an option for boost pressure gauge like the 2026 models have. I was hoping that might have snuck into an update.
Recall RRT - 25-197
Recall RRT - 25-237
Recall RRT - 25-239
