TaZer DT for RHO
LoPhatMelk
2025 Ram RHO
2024 F450 Platinum
I wanted to start a thread where we can track all info that becomes available on when the TaZer DT will be available for the RHO. While waiting on my RHO to get here I hastily bought the current model assuming it would work. After messaging Scott @zautomotive, turns out everything is different. I'm assuming this will be the same for all 2025 trucks and not just the RHO. If anyone has any inside info or anything to add please post it up.
I’m curious what features are you most interested in customizing your truck from this device.
Me too..
I know nothing about it.
I Googled it and found a listing on Amazon. First I'd heard of it. It seems like it has quite a few features and would be handy. It doesn't work with the TRX which makes me cautious about it working with the RHO in the future.
For myself: Amber DRLs, Auto hold and I think you can remove the seat belt chime. Delete auto start stop if that's an option as well.
Does the horn beep if you step out of the running truck with the key on you like Ford does? I deleted this via Forscan and hoping Ram doesn't have this annoying feature.
It worked on all 5th gen 19+ 1500s, up to 24. Including the TRX. It just seems there were some infrastructure changes on the 25s.
Tazer DT is an essential tool for owners of the new 2019 or newer Ram 1500 (New Body Style Only, including Ram TRX)
Simple, plug-in installation – simply unplug the SGW module and plug the Tazer DT Mini in its place. It is easily accessible, located above the OBD2 Diagnostic connector.
Tazer DT features can be broken into three categories:
• Vehicle Settings, accessed with the engine OFF and the ignition in the “RUN” position. These are changes made to the truck such as tire size, gear ratios or settings which accommodate other upgrades. These changes will continue to operate after the Tazer DT is unplugged.
• Live Functions are accessed with the engine ON. These are operations the Tazer DT performs live, only while it is physically connected.
• “Non-Menu” Live Functions are not located in a menu. They are activated automatically or with a steering wheel button combination. These are operations the Tazer DT performs live, only while it is physically connected.
List of Vehicle Settings
(ENGINE OFF)
• read and clear DTCs system-wide or inspecific modules
• change tire size
• change gear ratio
• change Transfer Case LOW ratio
• enable/disable TPMS system
• set TPMS pressure warning limit, front and rear, between 25psi and 85psi
• enable/disable backup camera
• enable/disable Cargo Camera input (8.4” and 12” NAV UConnect only)
• enable/disable CD (wired audio) input*
• enable/disable TravelLink/XM traffic and weather
• change daytime running lights (DRL) region (CA/USA)
• change DRL location
• enable/disable DRL Dropout function
• enable/disable factory fog lights
• enable/disable Fog Light Dropout (when fogs shut off while high beams are on)
• enable/disable one-touch lane change
• enable/disable factory halo lights (including BCM output for adding halos)
• configure vehicle for LED 3rd brake light
• change headlight type (Std/LED)
• change fog light type (Std/LED)
• change taillight type (Std/LED)/delete sensor circuit for running aftermarket lights
• change front turn signal type (std/LED)/delete sensor circuit for running aftermarket lights
• enable/disable Trailer Tow setting
• activate MOPAR Power Folding Mirrors
• activate mirror turn signals
• activate tow mirror lights
• activate approach mirror lights
• enable/disable Aux Buttons
• enable/disable Blind Spot Detection (if the hardware is added or removed)
• enable MOPAR power side step
• disable front axle disconnect module for axle swaps
• disable rear locker for axle swaps
• disable electronic steering pump for hydraulic steering conversions
• change cluster splash screen
• enable/disable PANIC button on remote
• one-touch return-to-stock – quick “Unmarry” function returns to stock.
List of Live Functions
(ENGINE ON)
• activate Light Show
• hold brakes at a red light
• enable navigation entry in-motion
• TurnCAM – activate backup camera when turn signals are used (5”, 7”, 8.4” and 12.1” UConnect) (excluding 2022 temporarily)
• Kill3Honk – disable three honks that sound when leaving running vehicle with keys
• ParkCam – activate SurroundView and front camera when front parking sensors are triggered
• automatically fold mirrors in/out on startup/shutdown
• override factory DRLs with amber DRL and turn on factory marker lights, including TRX hood lights in multiple modes (day, night or both)
• flash third brake light when braking
• customize third brake light flash pattern
• define Winch Mode RPM
• flash lights to indicate tire pressure while airing up/down
• Dark Mode – turn off all exterior lighting and dash/radio/shifter lights while parked with the engine running
• activate backup camera
• Force RWD (TRX only)
• activate 0-30 timer
• activate 0-60 timer
• display firmware version
List of “Non-Menu” Live Functions
(NOT IN A MENU — AUTOMATIC OR ACTIVATED WITH BUTTON INPUTS ONLY)
• AutoStopStart Disable – Tazer DT will automatically remember the last state of the auto stop/start system and set it for you the next time you start the vehicle
• AutoTracKill – Tazer DT will automatically remember the last state of the traction control system and set it for you the next time you start the vehicle
• Drive Mode Memory (TRX only) – Tazer DT will automatically remember drive mode and set it the next time you start the vehicle
• disconnect sway bar in 2WD up to 30mph or at any speed if mapped to a button
• Axle Locker Control – engage lockers in 2WD and 4Hi on demand.
• Cooldown Mode – turn on engine fans on-demand
• Winch Mode – raise idle RPM to user-selected value between 1300 and 2000
• Line Lock – lock the front brakes for an easy burnout
• Rock Crawl – lock all four brakes with a steering wheel button combo to hold the vehicle still, especially helpful when off-road
• TC Kill – turn off traction control, stability control and ABS
• show backup camera (shortcut)
• Turn Assist – lock the inside back tire for sharper turns (button remap function only)
• remap buttons to:
Any of the 8 light shows
Backup cameras
TC Kill
Line Lock
Rock Crawl
Winch Mode
Cooldown
Front/Rear/Front+Rear Lockers
SwayKill
Dark Mode
Turn Assist
Force RWD
• Partial Reboot
These are all accessed using the dash display, using steering wheel buttons to navigate the menus.
Ah, I stand corrected. The Amazon link I first looked at said no TRX.
Funny you mention auto hold. I just had a neighbor buy a new Traverse, his wife's Blazer got rear-ended and had to total it out forcing him to buy something ASAP. The dealership sales guy was trying to explain auto hold by having them sit in front of the dealership with the engine running and in gear to show how awesome the "feature" is that the SUV won't hit the dealership. *facepalm
I then explained it to him in a way that actually made sense. I should do a video or a video short on it. Most people, I'm finding, don't know what it is or what it does. However, once they do, I find a lot of them love it for stoplights and traffic jams.
I never had it prior to my 23 Tremor and now I am used to it and love it when sitting at a light. I rest my foot on the floorboard or even on the gas pedal without it going down before the light is about to change.
from what we hear on threads (in this forum and others) ... can bus changes, and SGW bypass changes for the 2025's wont allow current DT to integrate (or even plug in). I had the Tazer on previous RAM - DRL position/color, Fog Light Drop Out disable, tire size changes, Auto Mirror Fold (although I believe this is now an option in the factory menu) ... even had a "light show" option for flashing the LEDs in different sequences (more for a car show display or possibly for emergency/construction use) ,,, also cool-down (fan running after vehicle shut down) ,,,, ill be interested in the availability for RHO also - but for sure want stability first.
I have it on my Silverado and you can't turn it off. Its great until you are trying to backup to a trailer on a small hill and it keep holding each time you let off the throttle. I've nearly put the hitch through my bumper more than once.
Yet another reason I can't wait for this RHO to arrive and the Silverado to go!
Looks like Tazer just got their RHO.. hopefully soon
I found this video a few months back for the TRX. hopefully they come out with the RHO version soon. It looks like there's a good amount of cool stuff you can do with it.
A lot of us people in the Jeep world used the Tazer to change gear ratio after a regear, tire size change for larger tires, LED light swap from incandescent lamps, hyper flash on brake light, start stop disable and tons of other items.
Amber drls would be awesome! Should come like that from the factory
I like the white on our white truck but the yellow would look great on black imo !!
I talked to the owner several months back and it sounded like they were a good deal away and not in any real rush to launch new model compatibility. I can't recall what all he said but it was clear it wasn't a huge priority...at least at the time.
Also, these new models can do everything tazer does, it just needs to be added as a feature in the system. Hopefully RAM sees that and makes it so.
2025+ RHO Owners: Curved 23" PRO Bar in the Factory Opening Between the Grille and Bumper 37”  Debate - brand, size, weight etc… RHO range and MPG What did you do to your RHO Today? Just picked up my new 2026 RHO Highest mileage RHO
