Those of you who have installed Synapze DT
SynapZe DT — v27.0.6 — 2026 Ram RHO
1. White DRLs
2. Amber DRLs Day
3. Amber DRLs Night
4. Amber DRLs Both
5. DarkPark
6. WhiteLines
7. Drive Mode Memory
8. Auto Stop/Start Memory
9. ForceRWD
10. ForceRWD cancellation
11. Read DTCs across nine modules
12. Clear DTCs
13. Firmware Version Display
14. PIN Lock Immobilizer
15. Custom Security Code
16. Automatic PIN Re-Arming
17. Marry Menu
18. TPMS Enable/Disable
19. 3 Honk Enable/Disable
20. Seatbelt Chime Enable/Disable
21. Cluster-Based Controls
22. Firmware Updates via ZPU
23. Free Feature Updates
24. Plug-and-Play Integration
25. RWD Memory; Unmarry/Restore Configuration
Thank you for this.
1. White DRLs
2. Amber DRLs Day
3. Amber DRLs Night
4. Amber DRLs Both
5. DarkPark
6. WhiteLines
9. ForceRWD
12. Clear DTCs
17. Marry Menu
Thanks for this!
May be a dumb question, but what exactly does the following do?
17. Marry Menu
Thanks for this!
17. Marry Menu
  1. Marry Menu: This was added in the new 27.0.6 firmware. It allows you to marry the SynapZe to your truck and access vehicle programming settings. So far, I’ve found three options: disabling TPMS, disabling the three honks when exiting with the key while the truck is running, and disabling the seatbelt chime.
  2. Cluster-Based Controls: This just means you can control the SynapZe through your truck’s digital instrument cluster using the steering wheel buttons.
  3. Firmware Updates via ZPU: You can connect the SynapZe to a computer and use Z Automotive’s programming utility to install firmware updates.
  4. Free Feature Updates: Z Automotive has been adding new functionality through firmware updates without requiring you to purchase another device.
  5. Plug-and-Play Integration: The SynapZe connects to the truck’s existing electronics without requiring you to cut or splice factory wiring.
To clarify, 21–24 aren’t really individual modifications. They’re more so features of the device itself. I probably shouldn’t have included them in the original list.
It may have been an older TRX I saw this on, so it may have been a tazer feature?
Molten red or Delmonico?? día Arena Question about the red interior accents 2025+ RAM 1500 RHO / Rebel 23in Light Bar - PRO MOPAR Edition RHO @ Mark Dodge First look at Serrano Green
