Diode Dynamics HitchMount LED Pod. Clean looking and throws more than enough light to help with the reverse cam and warn others. Also ads a running light when parking lights are on. No brainer at around a hundred bucks when on sale. Easy to remove when I need to use the hitch.
Where did you mount the horn? Did you have to remove the grille? I want to do this but don’t see much room anywhere. Thanks!
I did it while installing my M&R light bar, so yes the grill was off.
Mounted it at the bottom of the opening and Mounted the motor for the horn on the back side for the vertical brace.
Wired it to one of the aux switches and in settings changed the switch from latching to momentary.
You really don't see the horn unless your looking for it. The horn is below the ram if you zoom in.
Thanks brother, appreciate you.
Just picked it up and brought it home. That basketball hoop was an immediate removal! Now she needs a bath from the 300 mile trip.
Wired in and mounted the Airlift Wireless One.
Anyone running right off an aux switch? I had initially wired it to the battery but I’m thinking the switch is the way to go.
Later this week I’ll be rerunning the airlines from my current setup to the compressor.
Ran all the wires in PET braided sleeving for extra protection and will do the same on the airlines.
I ran it to the battery. You have the second ignition tap to keep it from running when the ignition is off.
I ran my ignition switch to one of the aux switches and the battery line to the battery.
Not sure where I had gone wrong, ran the one to the battery and the other to aux 2 switch, it was still cycling on when the truck was off which is why I pulled the battery lead and have it running from the switch only.
Yesterday I put 7/8 of a quart of transmission fluid in her...
Did first oil change...I can't believe I have been doing this shit for so long without a splash pad!!!
Because it was not full...I am sure that amount may not make a difference,but I have ocd when it comes to my toys.
Did you check it just for the sake of it? Or did something cause you to check it. I’m not being argumentative just curious.
Just for the sake of it...Can't say I have faith in the QC of Stellantis...I was going to check the rear diff and transfer case, but my back had enough of rolling around under my truck.
Sweet, maybe I should check mine too.
Dressing Up Hardware Behind the Wheels-Questions Marker Lights 2026 RAM RHO Order/Schedule/Build Thread Aux Battery Swap for H8 Main Battery Carpeted Floor Mats Wanted What did you do to your RHO Today?
