I kinda hate the RAM logo on the tailgate but can't remove due to holes it leaves behind so I inlayed some fake/vinyl carbon fiber into it. R without A is with it.
I’d buy actual carbon replacements if someone made them. That would be cool
Ionic volt electric steps and Gen3 BakFlip MX4 installed
I had a local shop install the Ionic Volt steps which they said it was a bit of a tedious process to install with all the wiring. Most our accustom to installing amp which plugs into OBD2 port. Amp was out of stock and I didn’t want to use my OBD2 port since I’m installing the Cat6, not a fan of the splitters either. Steps look great though and function really well! Price point on the Ionic volt steps is great too, just over $1k. Steps retract quickly, going down when you open the door and then back up quickly when you close the door. Also, I love that you can’t see the steps are installed when they are retracted under the vehicle. Very happy with the look and function of the steps.
Installed Gen3 MX4 earlier today and it was pretty easy. Install took about an hour including clean up. This model is definitely a step up from previous versions in overall quality, fit, and finish. I’m in Florida so look forward to see how it does with the rain and keeping water out. I know it’ll have some water intrusion which I expect to be mainly at the tailgate on the corners. Also, they even sent some extra parts like replacement corner caps since they can wear over time. But, happy with the look and installation process. Look forward to seeing how it holds up.
I can’t stand the giant RAM letters either. This is the first thing I did to my truck. Like you, I wanted to remove them, but couldn't , so tried to make them much less noticeable. I found vinyl that was as close to my paint color as I could get.
That’s not bad
Where did you get them from? I have the same color and want to do that you my truck when it comes. It looks Great!
Nice job
Lol. When I ordered the carbon fiber, I ordered silver logos too but tried the carbon ones first. Silver looks good!
Was looking for yellow but doing blue for now.
Switched over to 37” tires and moved the spare tire to the bed after installing the factory tire mount. Then modded the bed cover by moving one of the brackets further up. Now everything is nice and covered up and not exposed to the elements. Small hump in the back but hey it’s a Rhino 🀩
Fantastic!
Got my ARK MicroFlares in last night...just need to install them. For those of you that have them....did they come with hardware or are we supposed to use the factory bolts?
I got their standard flares which used the factory screws plus one hole drilled in the liner. I'd guess with the micro flares, those extra drilled holes aren't needed.
Rear fender flare RAM RHO Canyon Lake Photo Thread What did you do to your RHO Today? 2027 RAM RHO Order/Schedule/Build Thread Rumble Wraps Decals Progress of build
