@Jramos44, I think you were using the Vibrant 1795 resonators at one point. I’m growing tired of the standard MRT Trail Rated system but none of the other systems out there impress me.
Based on your exploits do you have any thoughts on adding the Vibrant 1795 resonators to the MRT Trail Rated, or maybe swapping the mufflers on that system for the Vibrants?
I’m primarily looking for a deeper tone, I’m not chasing db, and those Vibrants sound pretty deep on some of the video clips I’ve seen.
I’m not to familiar with with the trail set up to give you an opinion, are they mufflers or big resonators, if they are just straight through perforated with packing then I think the vibrants will be just a bit louder. In all honest I was just running cheap amazon resonators, they work just the same as the vibrants and are half the price.
MRT describes the mufflers that come with the Trail Rated as typical muscle car mufflers.
They give the system a nice smooth sound with almost no gear shift wet farts but the tone is fairly high pitched.
Thought a $200 (or less) pair of resonators might be worth trying.
Well I had that set up with the double x pipe and it sounded good and had no drone so I’m sure you will like it.
  • Like
Reactions: rpr
Very Interested as well!
I installed my PSP downpipe with the AWE exhaust, 10 out of 10 would not recommend. I had to go have my stock exhaust put back on which sucked because I wanted it to fit in the back of my truck so I chopped a piece off. So, that had to be welded back up. And then I had them change the H pipe for an X pipe and now the trucks super quiet basically sounds stock.
I thought about taking the suitcase and replacing it with a dual in/dual out. Leaving the passive valves to tame cold starts. Then if it drones which would happen in the rear maybe if I find another set of passive valves someone chopped off… Have them welded on at the back. It would be loud when I gave it gas but sitting at a stop it would be tame.
If oh leave the valves in I think you should be safe on the drone if you swap out the big muffler for a smaller one
I would agree. I swapped back to stock exhaust and am debating the same. Taking out the giant muffler and putting in a dual in/out that has more resonance.
I ended up selling my mbrp system as a Trx cat back so I sell have the front pipes that connect to the down pipes. I’m thinking of using those with the stock system to get rid of that squished pipe and swapping the h for a x pipe. Just debating if I should put the stock valves somewhere so I can chase some loudness, my current set up is pretty tame.
Why do you not recommend the AWE with the downpipes?
I’m sure it’s unbearably loud in start ups and has drone. But the unbearably loud might work for you I’m guessing from your other post.
If it's just unbearably loud then that's exactly what I'm going for. I'm curious to see how the drone is.
Please tell me you shot some videos of that.
Well I promise to get some videos once my pipes come in, but I didn't go with PSP
My AFE is for sale and I am in Orange County if you are interested. IT WAS LOUD! Looking for $650, shipping would be extra if the drive isn't worth it. :)
I currently have AWE, to my ears that's the loudest on the market
Rear main seal leak RAM RHO Canyon Lake Photo Thread What did you do to your RHO Today? RHO Delivered Eibach Pro-Lift Kit Installed I don't want air bags -- how about Timbren?
