X pipe will cut out lower frequencies and alloy the raspy higher frequencies. H pipe will cancel high raspy frequencies and allow lower frequencies deeper tone and better low end torque.
Muffled xpipe on mine made rasp non existent and deepened the tone significantly. 🤷🏻‍♂️
Our twin turbo motors are like two 3 cyl motors tied together. Two separate but integrated 3 cylinder manifolds two turbos each with their own exhaust. It is highly unlikely both turbos will be balanced. this is where the H pipe comes in to balance the back pressure. With out it acoustically it’s like listening to a cat fight. Placement ideally needs to be at the point where the exhaust gasses stop accelerating due to thermal expansion and just start slowing. On our trucks this where the two exhaust split their path. One side is running across the trans pan and the other side is next to the transmission. Obviously they can’t put it there. So they placed it just after where the exhaust pipes come back together and are running parallel again. (Hopefully now the cats stop fighting and start purring together.)
Pinnaclebuilt does this sound about right?
I ended up swapping my factory H pipe for the X pipe yesterday. I would record a video for the sound bite, but it sounds similar. If not, barely different. I would say there’s a touch more raspiness in the middle of the RPM band, but not by much. The cold starts are a bit tamer and the drone went from a three out of 10 to maybe a 2 1/2 out of 10 not much difference. I will say that the power band does feel much smoother across the board and feels stronger on the high end. So if anyone’s curious, I have the stock exhaust behind the down Pipes with a X instead of a H, valves removed, and four stainless browse resonators added to the system.
I could be wrong, but that looks more like a D pipe. A variant of the X pipe. I was wondering how that would work. Now we know.
I got my rasp and drone down significantly w this set up. Don’t judge my welds. PSP- stock front exhaust up to H pipe- 2 16” Amazon cheepo resonators- another H pipe i rigged up - then 2 knock off ultra quiet’s at the ass end. I’ll upload the cold start in a bit. Slight rasp when i get on her hard but cruising is solid. I would’ve loved to keep the nasty growl but every day driving was embarrassing w the rasp.
Nice excited to hear
That's a wild setup. But I gotta give it to you, after the ultra quiets, that's probably the best sounding exhaust with downpipes I've heard. At least on video! Good job, I have hope now and less scared to get downpipes.
Thanks. I liked the way Jramos’ exhaust sounded when he had the double H. So i figured I’d break them up instead of back to back w the res in between. Just winged it really. Got lucky cuz idk shit about exhaust frequency.
What downpipes are you using ?
Stock. Its the set up i was going for. 25%-30% louder than stock. Deeper tone and no drone. Perfect for me and good for wifey. I like hearing my stereo and bass. Stuffed my subwoofer with polyfill.
Ill do a rev video soon. And I only have 200 miles on the mufflers. Packing material hasn't loosened up yep. Should get a bit deeper.
Second start is w the ultra added. And it’s def a cold start. Sat for 2 days.
Sorry bro I was driving when I first watched it I didn’t. See you explained in the video. Great job man sounds good , got rid of that annoyingly loud cold start. Freeway drone ?
Got a pic of the 2nd H pipe you say you rigged up? Would like to see the location.
Ok, well your set up sounds good, I was just confused because this is a thread for exhaust with downpipes. Anyways let us know if you ever add downpipes to your set up.
Exhaust Options Fuel Wheel Price Drop! Post your favorite picture of your RHO Incentives Update on RHO from MARK DODGE MOPAR Edition RHO @ Mark Dodge Eibach 1.6 vs 2.7 front only
