Yes. Part #400482. Bought em on Amazon.Thanks, seems to sound better than my cold start with the dual in dual out Magnaflow on the MRT Trail Rated:
Borla has a Pro XS with an offset/offset and a center/offset. I assume you used the center/offset (Part No. 400482)?
It has to be an xpipe muffler to cut out the rasp.
Unfortunately that was my experience with an x-pipe muffler on this truck. Higher frequency tone, very whiny, not good.X pipe will cut out lower frequencies and alloy the raspy higher frequencies. H pipe will cancel high raspy frequencies and allow lower frequencies deeper tone and better low end torque.
Understood I was trying to give a short readers digest version of an explanationnot so simple. the size and placement of the h-pipe make a dramatic difference in acoustic coupling and sound. adding a second hpipe can attenuate lower frequencies, again depending on size, spacing and location. The same thing with an xpipe, where you place it matters based on the frequency wave length at a given temperature. It can have a larger impact on frequencies if centered at the 1/4 wave length of said frequencies.
That being said you can use h-pipes to tune the sound more effectively than an xpipe as you can couple them with spacing.
The oem h-pipe is that diameter and at that location for frequency attenuation and has no positive impact on low end torque. You can make the argument it negatively impacts low end torque as you are introducing a turbulent piece into the pipe. Turbulence aka pressure drop aka back pressure is the enemy of a turbine wheel and spool.
blending the exhaust pulses is more beneficial from a performance aspect on a N/A engine as those pules are much more defined. On a turbo car the turbo manifold and turbine wheel substantially smooth those pulses so they are not as sharp or abrupt. So again on a turbo car an H-pipe has more effect on the acoustic waveform than functioning like a tuned header directly to cylinder pressure waves of the N/A counterpart.
Thanks for coming to my TED talk....
Muffled xpipe on mine made rasp non existent and deepened the tone significantly.X pipe will cut out lower frequencies and alloy the raspy higher frequencies. H pipe will cancel high raspy frequencies and allow lower frequencies deeper tone and better low end torque.
I could be wrong, but that looks more like a D pipe. A variant of the X pipe. I was wondering how that would work. Now we know.I ended up swapping my factory H pipe for the X pipe yesterday. I would record a video for the sound bite, but it sounds similar. If not, barely different. I would say there’s a touch more raspiness in the middle of the RPM band, but not by much. The cold starts are a bit tamer and the drone went from a three out of 10 to maybe a 2 1/2 out of 10 not much difference. I will say that the power band does feel much smoother across the board and feels stronger on the high end. So if anyone’s curious, I have the stock exhaust behind the down Pipes with a X instead of a H, valves removed, and four stainless browse resonators added to the system.
What downpipes are you using ?Cold start a little closer to the tail pipe. Stock into MRT trail rated pipe, Borla pro xs mufflers, into MRT trail rated pipe, then all stock.
Nice excited to hearI got my rasp and drone down significantly w this set up. Don’t judge my welds. PSP- stock front exhaust up to H pipe- 2 16” Amazon cheepo resonators- another H pipe i rigged up - then 2 knock off ultra quiet’s at the ass end. I’ll upload the cold start in a bit. Slight rasp when i get on her hard but cruising is solid. I would’ve loved to keep the nasty growl but every day driving was embarrassing w the rasp.
Much thanks to you. U bit the bullet and started hacking lol.Nice excited to hear
That's a wild setup. But I gotta give it to you, after the ultra quiets, that's probably the best sounding exhaust with downpipes I've heard. At least on video! Good job, I have hope now and less scared to get downpipes.
