I couldn’t live with the cold starts it was embarrassing for me. I’ve had a loud cars and cold starts, but being loud and sounding bad as much worse than just being loud for example I had a straight pipe scat pack for a couple years and that was a loud cold star, but it didn’t sound bad.
Exactly how I feel. But I was not at all happy with stock and not happy with the tone of the MRT Trail Rated so torn on what to try.
It really is a horrible start up but makes up for it when idling down. Drone really doesn’t phase me much. We’ll see tomorrow if it’s as bad as wreckless’ clips while driving.
What's so bad about the startup? Didn't sound bad to me.
Crazy how different it sounded over the other guys video. That's what sucks about trying to translate audio over a cellphone mic and then out a cellphone speaker, it will never do it justice
I’m going to swap the stock h pipe for a X and add the valves back , then I think I will be safe to swap the stock muffler with a smaller dual in dual out muffler, I really think that sweet up will be a good compromise on sound a volume without have drone because of the stock valves.
It’s so loud , but the main problem isnt the volume it’s the tone of the loudness it’s so unpleasant.
Yea i was fully expecting a rattling tin can. It’s louder in person tho. Can’t say that i hate it, just sounds like i have the exhaust pieced together w duct tape and its about to fall off on start up lol. When u putting urs on? Curious for comparison.
U think messing w the valves could help with anything? Like making them not fully close by limiting how far it opens and closes. Or maybe lighter spring tension. I seen u guys mess w a bunch of different exhaust orientations and resonators, but no one messed w the valves yet. I’m no expert, just thinking aloud.
I don’t think the valves will help with the crazy cold start but I do think it will mitigate the drone on the freeway.
I know the valves serve a purpose but the idea of putting a restriction back in my exhaust is tough to wrap my head around. Even fully open they look like they still result a ~25% diameter reduction. I would much rather try to add flow through resonators but that’s always a gamble and the valves are more a known variable.
Regarding the horrendous cold starts on these trucks this may be the wrong thread to ask but does anyone know if there any options in the aftermarket tuners that could tame the high rpms on cold starts without causing issues?
I’ve never seen any discussions with Stellantis’ engineers as to why the rpms need to be so high on cold starts. I’m sure there’s a reason (likely oil flow and lubrication related) but that doesn’t necessarily mean that reason has been fully vetted, tested and verified to be absolutely necessary. Stellantis’ engineers are just people and theory doesn’t always translate to reality.
But…likely something not wise to mess with.
If I remember correctly Dballz/ Pinnaclebuilt said the opposite. They tone down the start up idle sound level.
The issue with resonators is they do nothing for the drone in terms of the frequency that causes drone they only take down the higher frequencies, trust me I know I have 4 resonators in my current set up and there’s still slight drone (livable) the way I see if if I add the valence s back in but get rid of the swished pipe under the transmission then I’d call the flow loss/gain a wash.
They might tone it down a bit but the rpm’s on start up are so high that I’m sure the valves are open anyways. It’s my understanding that the valves are there for freeway drone.
Did you ever pinpoint the problematic frequencies?
Also, do you or does anyone else know if MagnaFlow’s SPEQ exhaust has true Helmholtz resonators? I believe those can be designed to eliminate the lower drone related frequencies but no way to know how MagnaFlow has tuned them. They don’t use Helmoltz terminology, they refer to them as “No Drone Technology (NDT) chambers” but they sure look like Helmholtz resonators.
That would be easy enough to verify. Just slide under the truck at idle and look at the clock spring position. I would look at mine except for mine have been clamped open for the last 10,000 miles. The reason I clamped them was because the rattle sound they made at an idle drove me nuts. I’ll bet they open a little, maybe 25% at idle, but that’s about all.
Looks like I’ll be adding resonators lol. Took it for a spin and got on her a bit. Felt like the truck morphed into a Honda. Great power. Horrible rasp.
Yes frequencies were 110-120 hz mostly , I couldn’t find anyone to make me a Helmholtz resonator to fix this for me so I just settled with have a quest stock exhaust. Only problem is without the valves I now have a bit of drone it’s just livable because my exhaust is inky loud when your really getting on it. I am change to a x pipe to see if I can get away with not having the valves. Plus in all my experiences the power was much smoother with the x pipe vs the h pipes.
  • Like
Reactions: rpr
I have tried everything for this truck, chasing a reasonable exhaust tone.. finally have settled on dual 2 (3") into 1 (4") mufflers with a 4" single pipe center section. Got this idea from the BMW guys.
I originally thought I could leave the exhaust alone, but after downpipes I was not happy with how much louder the shitty tone was. I started by adding the flowmaster fx as suggested here, then resonators where ever I could fit them, plugging the factory screens, and variations of all this... I was close to giving up and just going back to a hemi 1500 (had a '20) . The wife has a grand wagoneer (same motor) that sounds perfect, and I love everything about this motor so thought I'd try the 2-1-2 as a last resort. I so far think this is the ticket. Sounds like the wagoneer with a bit more sputter, but otherwise pretty quiet like I wanted and I even think I picked up some top end.
Point of all this is to say I dont think keeping the dual exhaust is ever going to sound good to some of us, after downpipes, and wanted to offer up this as an option.
What did you do to your RHO Today? Alignment after eibach 1.6” front install MX4, disappointed We got movement - 19 Nov Order JANUARY order updates! 37’” Tires / MPH / Speed Rating
