RAM RHO HO Downpipes with High Flow Cats +100hp!
Keeping an eye on this... interested! Love the low end and mid range gains.
Deeper sounding and way more volume so would need to adjust exhaust, currently have 2 Vibrant 17950 resonators could just add a couple of their shorter ones further up no problem.
Typical 1 year warranty?
Can these be sent out ceramic coated also for a little more heat coverage? If not I'm sure I can find a local shop to do them.
I’m not so sure ceramic coating a catalytic converter is a good idea. It may change it’s temperature parameter.
Cats carry a 1 year warranty, so yes.
I don't have the ability to ceramic coat on-site so it's not in the cards.
Keep in mind that the factory ones did have an issue with melting so these are designed with the intent to dissipate heat at a much faster rate then the factory cats. The reduction in back pressure plays the biggest part in lower egt's but I have no idea how much that will change with ceramic coating.
Did you just remove the stock muffler and swap the Vibrants in?
I’ve heard a couple of sound clips and these have my attention… but curious what your observations were compared to stock.
Hmm sounds like it's not ideal or necessary to coat like a couple of other manuf push... I've done coated long tubes a few times and glad I did there but those were an NA 392 and a supercharged/hellcat Challengers. Other than a few cummins trucks this is my first turbo I6. I'd hate to trap heat in the cat against its design, results may be bad.
Left the H up front as is. Removed giant stock muffler and valves and welded in (staggered) two 17950 Vibrant resonators (18" full length and 5" diameter). It's definitely a little deeper and louder than stock but not super impressed. But not sure I would be with anything. Trying to get BMW TT I6 clean performance sounds out of this length/configured exhaust is difficult. Likely that I go back to stock once I add the downpipes and/or add another pair of Vibrant resonators further up or small muffler + current resonators.
In my opinion do not remove the H-pipe up front. The amount of suppression it makes in the 180-230hz range is crazy. I took one out and replaced it with resonators and it was louder and sounded worse than without resonators....
These trucks have a weird resonance on cold start and part throttle when you replace the factory cats. It seems to peak in that same frequency range 180-230hz. Full throttle sounds great but IMO it's a bit too loud (I'm old) part throttle and cold starts.
I really like the borla front muffler design they have in their system that incorporates an H-pipe. I may buy a system just to use that front piece, again because I'm old and like quiet.
The x-pipe mufflers may be a good choice as well to put in place of the factory H-pipe. Tame the raspy peaks and smooth out and lower the tone...
I have a couple of front h-pipe sections I think I'll probably throw flowmaster x-pipe muffler on one and see how it sounds with the down pipes and factory exhaust
any estimated shipping dates yet?
Would you say it’s as loud as straight pipe compared to having the Vibrants?
Thanks for the info - definitely interested in hearing how the exhaust experiments go. On this particular setup... quiet deep performance tone is all I want so we are about on the same page. Once I get a set of your DPs I'll be adding a couple more resonators or going back to stock muffler plus a small set of resonators somewhere but likely without the valves (massively improve flow at the DP/cat then keep valves in the way... rather not). So hopefully whatever combo I land on is mild driving, decent idle and start up "authority" lol... only wild @ WOT.
I never ran straight pipes on this truck and wouldn't. I doubt it's as loud I'm sure the resonators pull back a few db especially since I used the 5" diameter 18" long option.
Anyone know the difference on running x pipe vs h Pipe
There is already an h pipe farther up the line...adding muffler or system with xpipe as well, will tone down the rasp.
I see a lot of catback systems are replacing it with an X, my plan is to muffler delete and add Dynomax Bullets, but wanted to know if swapping out H with X makes a difference.
Someone did that...they deleted the muffler and valves, welded two small round mufflers to an xpipe.
I currently have the MRT Extreme. For what it is, I think it sounds great.
I’m pretty sure it’s going to be obnoxious adding the down pipes. I’m not sure if I should add a muffler back to the system or just go with a couple resonators?
I have the MRT Trail Rated exhaust and I’m considering adding downpipes but I would agree that adding downpipes to the MRT Extreme would likely be way too obnoxious.
Most of these aftermarket systems are too obnoxious for me without downpipes. They don’t change the tone much and to my ears they primarily just amplify the unpleasant tone of the stock system, except for the MRT Trail Rated, but I’m old…
I would likely need to wear hearing protection in the cab with the MRT Extreme + downpipes. 😂
Had to get a new batch of brackets due to an error at laser which pushed us back a few days. That being said they are coming together now.
Production set ready for O2 bungs and brackets then out the door.
Closed on a 2026 RHO today Zippo RAM RHO Mopar edition What did you do to your RHO Today? YOUR RHO IS NOW OBSOLETE *** Post New RHO Photos Here ***
