Took a better picture for you.Kinda surprised there are no openings or anything like it looks like @Eighty has in the pic above mine.
Throw a stealthbox in! They fit perfectly under the seats but you do lose that area for storage. Pretty sure you can do two 12’s, I opted for two 10’s.Ok so what can we fit in the stock sub space? Anything worth while or jus do custom box?
That’s a clean build. Had I not gone with a custom box, that’s exactly what I would have used. I do wish Ram would have given us RHO folks an option to upgrade to the Klipsch audio available in the Tungsten. It’s actually a legit system with a good low end punch.Throw a stealthbox in! They fit perfectly under the seats but you do lose that area for storage. Pretty sure you can do two 12’s, I opted for two 10’s.
Do you know what that cable is for? The more I listen to this system and adjust it there is nothing redeemable about it. I pushed everything to the back and turned up the bass and mid and it emits sound but none of it is bass which makes me think there is an amplifier issue with the bass? but that doesn't explain the rest of the speakers and not sure if it the quality, the need for a proper sound processor or more power. The stereo in my 23 PW was far superior with less speakers than this pile of garbage.Double confirmed the speakers are there. Reach in from the middle, find the string and pull. You might have to try pulling outboard vs inboard but it does work.
I have a L1 with the HK and I do have sub because I turned the bass up to 11 and could feel it, but barely. From looking at the back wall of the cab you wouldnt know anything was back there. Also had this empty plug which initially made me suspicious no sub was there.
So the subwoofer is disabled before activating digital key?You have to message ram cares with your vin to gain access. Ram will roll out subwoofer access right after they are finished up with the digital key updates.
Go to the dealer and have them pull a limited out if they don't have a RHO...Compare your truck to another HKDo you know what that cable is for? The more I listen to this system and adjust it there is nothing redeemable about it. I pushed everything to the back and turned up the bass and mid and it emits sound but none of it is bass which makes me think there is an amplifier issue with the bass? but that doesn't explain the rest of the speakers and not sure if it the quality, the need for a proper sound processor or more power. The stereo in my 23 PW was far superior with less speakers than this pile of garbage.
My base RAV4 system has more bass and it doesn't have a sub. I thought that system was bad and now it sounds kick ass lolIt seems the systems leans on the center dash speaker in surround mode and the sub never seems to fill the void and in turn only increases the the void.
I have tried every adjustment and I punched everything to the back and nothing. I don’t k ow if it's the system, The harness, the amps. Or the sub itself because there is no bass anywhere in my system.Lots of bass in mine, you can definitely tell there is a subwoofer back there. Turn off surround sound and you'll be much happier with the sound staging and output of the system.
