RHO Mud Flaps
They are excellent for the money. I cant find any difference between them and the weather tech
They don’t fit.
I purchased them using the Amazon link below and the rear doesn’t fit. The bolt holes don’t come close to lining up. Did you modify yours to make them fit?
They don’t fit.
The bolt holes DO lineup. The molded in relief only fits from the top and down the side. It doesn’t match up right on the bottom edge. bolt it up anyway. Three washers between the flap and the truck at the bottom hole. Two washers at the next hole up. Then one washer on one after that. No washer at the top hole. Without the washers it’ll still bolt up, but it winds up with a bit of a twist at the bottom.
The bolt holes DO lineup. The molded in relief only fits from the top and down the side. It doesn’t match up right on the bottom edge bolted up anyway. Three washers between the flap and the truck at the bottom hole. Two washers at the next hole up. Then one washer, one after that.
That makes more sense. Thank you!
Ark micros installed and looking sleek.
I like this option. I was hoping someone else would offer splash guards for comparison but looks like Ark will take my monies.
Don’t hesitate. I took the picture at that angle to show that they can actually come out a bit further if you wish. I may adjust the rears out further but for aesthetic, they look great.
Installed TRX rokbloxz on mine, fit real nice front and back. These were the regular size not the large.
I have had them on since week 1. With the running board protection I’m at 8k miles and not a mark.
I have RokBlox on mine, they utilize the OEM screws. The install was about as easy as it gets. The part number on their website lists it as fitting TRX & RHO. I bought the XLG size.
Just wanted to pop in here to say Weathertech will be working on the rears for these ASAP.
Banks Power Monster JANUARY order updates! Apex Auto Styling graphics are in No mud flaps? PPF and ceramic coating over hood graphics? Seat belts
