RHO Wheel spacers
Sorry, yes. They are the HFX-1, 20x10 -18mm Matte Black. Follow the journey in the member builds section, Dua Leapa.
I think your truck is one of the best looking RHOs...the storm trooper look is 🔥. I love white vehicles, this truck is the first time I've had black in over a decade. Usually I go white with black accents.
Thanks brother! I’m proud of it. I love seeing everyone’s personalities and design come through the different builds. Oddly enough, this was the first truck I tried to change the color on but the request was too late. 😂 Blessed to be able to have things like this for sure, and still jealous of all the Porsche guys.
I found the above as well, seem very high quality/well made.
I like the OEM wheels & tires, would just like a little more offset 1-1.5". Even if I spend ~$600 on quality spacers, I would imagine that's still less than a new wheel set with lower offset than factory wheels.
What wheels are people going with that have less offset than OEM? Say something like -25 or -38mm offset? Thanks in advance everyone!
-12mm, -18mm and -24mm. Stock is +19mm. Buy Bora spacers. Best in the business.
What's everyone's opinion on the aFe spacers?? Maybe @Nick797 can chime in?
Link to spacers you went with please? Thank you in advance!
Here you go. They have them with chrome or black extended thread lug nuts for factory style lugs or aftermarket style lugs. The lug nuts actually extend through the lug holes to keep full thread engagement. Mine haven’t loosened up at all.
Does anyone have the direct link to the Bora 1.5 inch spacers. Currently running 0 backspace Fuell Covert Wheels and would like little bit of a push out
Yeah, there are several places that also sell the ones that appear to be from Coyote, but I guess there were some counterfeits being sold via eBay and Amazon that were made from crap aluminum that also fit poorly and had shit lug nuts according to the TRX forum that turned me on to them. And I wouldn’t use any hub-centric spacers without the extended thread lug nuts, that’s what I love about them. Using the existing studs and still having that thread engagement.
Does anyone know if the RHO wheels have a ball seat or acorn seat for the lug nuts. I see the extended lug and spacer kit above says "factory wheels" but they are acorn seat. My 2022 Ram oem wheels had ball seat. Big difference.
The factory wheels have what I believe they call a 'bulge' lug nut, most aftermarket have the standard acorn or are the flat/washer style. I ordered the ones for the factory wheels and they fit perfectly.
Added 1 1/2" wheel spacers stock wheel/height (1st pic is no spacer comparison)
looks great on rear, the front sticks out little too much.. is it rubbing?
Those of you running spacers, how about an update...any issues so far?
No rubbing at all, it's the lowest spacer you can go before the factory studs hit the back of the wheel and I wouldn't want to cut my factory studs since this is only temporary until I decide to get wheels
No issues at all, I would just double check that they don't come loose just like you would your wheel studs on wheels but mine haven't came loose at all no issues
I have always used BORA spacers and have never had a problem. I run 1 3/4 inch spacers with no rubbing. Before the haters comment, I double check the torque with 2 different wrenches and only use BORA as stated before.
Nice! Eyeballing the aFe spacers currently.
Carpeted Floor Mats Wanted Dragy Times Thread! From long time lurker to 27’ owner What did you do to your RHO Today? What did you do to your RHO Today? What did you do to your RHO Today?
