Shaving Emblems
On my old ram.. I had the detail shop remove it for me for free, before applying ceramic coating
Anyone have pics? Specifically of tailgate big RAM?
I plan on removing the 4x4 on the back and the two 'ram' emblems on the side.
Same, but I'm also doing the RHO emblem on the back too.
  • Like
Reactions: RH0
You are going to have alignment holes to fill if you take the RAM off the tailgate
Excellent question as I'll be removing everything, on my '24 gmc there were no alignment holes
This thread may be helpful.
You can remove “RHO” and “4x4” easily as there are no alignment holes. For the large RAM letters, there are many alignment holes and if you want to remove this emblem you need to find a good body shop to fill in those holes.
Has anyone shaved the emblems off of there RHO yet?
I'll be giving mine a Brazilian because she deserves it. RAM on the back is gonna be hole-tastic, and I'll either fill em or fabricate something different that uses the stock holes. Either way its a bit of work.
Thank you, Team! That’s exactly what wanted to know. Looks like the big RAM stays.
I’ve removed the “4x4” from the tailgate. Used non-wax dental floss to “saw” thru the adhesive backing. The adhesive came off with either WD40 or rubbing alcohol…I don’t remember which.
I’ve found most automotive adhesives are safely dissolved by either WD40 or rubbing alcohol. If one doesn’t work, try the other.
After fishing line or floss, I use goo-gone or goo-off and then just thorough car wash to get any remaining chemical residue and ceramic after.
I want to take off the RAM off the sides and replace it with the RHO emblem
RAM 1500 RHO Nameplate - What's your take on it? Carbon Fiber Driveshaft with billet Flanges $2750 RHO Build Tracker What did you do to your RHO Today? RHO Member Order Monitoring/Listing Who still does NOT have a scheduled date?
