Shifting issues at WOT.
Does your truck bounce off the rev limiter when shifting from 1st to 2nd at WOT?
  • Yes, and I have a 2”+ leveling kit
    Votes: 4 9.8%
  • Yes, but I have less than a 2” leveling kit
    Votes: 0 0.0%
  • Yes, but my truck is stock
    Votes: 0 0.0%
  • Nope. I have a 2”+ kit and my truck is fine
    Votes: 0 0.0%
  • Nope. I have less than a 2” kit and my truck is fine
    Votes: 3 7.3%
  • Not sure. I haven’t launched my Truck.
    Votes: 7 17.1%
  • No issues, and my truck is stock.
    Votes: 28 68.3%
  • Total voters
    41
Eibach made zero modifications to these springs over the TRX, although the motor weighs less. The 2.7/1.6 was the same part numbers as the TRX.
I’m a bit disappointed by this because my front sits just slightly higher than the rear.
Your front sits higher stock, or after leveling ???
After. Eibach being Eibach decided to just throw the same springs in a vehicle with totally different specs, so the lower weight in the front caused it to not compress enough to actually be level.
This.
Which really confuses me because all three of the ones I've seen at lifted trucks look good. Unless they are putting the HD spring in the rear idk.
Like this photo , about a quarter inch high in the front just a guess
Definitely has a (slight) forward rake. I went and measured the white one on the website and posted the measurements in the eibach thread.
This truck looks good and level to me ! It actually looks lifted at both ends to me, but level !! I want mine to look like this !!!:ROFLMAO:
Yup, I can confirm. I have the exact same issue. Contacted Dave, at Eibach, and all he told me after sending in photos and measurements was, thanks our engineers are looking into it. I asked him if they had any sort of ETA for a solution and got ghosted.
I wonder if and when Eibach intends to address this with a new spring or kit. I left them an email too...
I saw on youtube that an owner went with 1.6f/1.5r and his looked the same as the pro kit with only 1/4in rake. Makes me want to try the rogue kit, bottom piece only, and see if 37x12.50r20 with -18mm will fit.
The IGM videos with Rogue are a bit misleading as I had to read through the comments to find out they installed the perch kit and top plate, but removed the spare tire to keep it level.
I even asked about this before ordering and was told their "engineering team" looked in to it and this was still the right spring !! I still call bullshit, but i bought them anyway !! Haven't put them in yet, but soon !! ( I think its gonna be high in the front, but that should be better than low like now) !!!!!
I saw on youtube that an owner went with 1.6f/1.5r and his looked the same as they pro kit with only 1/4in rake. Makes me want to try the rogue kit, bottom piece only, and see if 37x12.50r20 with -18mm will fit.
I'll be removing my spare today and snap some pics.
Do you mind sharing your findings and photos/measurements here? I emailed Eibach tech support again today and was told they are still looking for a truck in So Cal for testing.
My truck is at foutz for some test fitting of a few things. They want to mount the 1.5 the 2.0 and the 2.5” up. I’ll see if I can get some side profile pics as well.
*** Post New RHO Photos Here *** From long time lurker to 27’ owner We got movement - 19 Nov Order What tires is everyone running 5,500+ mile trip. Non dragy times!
