Stealth performance
So I did two launches so far with the stealth. I don’t have a draggy yet, but eventually. I live in Jacksonville, Fl. So practically every road is flat. 3/4 tank 3400 rpms sport mode traction control off. 4.10 0-60. Second launch. Next day (today). 1/2 tank launch 3600 rpms sport mode traction control off. 4.0 0-60. So far I’m really enjoying the simplicity of it l, and was pretty simple to put on after I was told to go through the front passenger tire well. This is also the first two times I’ve actually launched. So still learning how to get that perfect launch. So I’m assuming with a 1/4 tank and a better launch i could probably get down to the 3.7-3.9 range. Throttle has definitely improved over factory. Hope this helps anyone who is curious about it, or thinking about one. Overall pretty damn good. Only thing I miss on my cat6 is the throttle control. But for simplicity, this thing hands down is great for set it, and forget it. I’ve left mine on there map 3 the whole time.
Anxiously waiting for more results as the simplicity of this would be perfect in my world. 16 months and 17k miles with only doing a lot of exterior exhaust and suspension mods iI’d really like to enhance the performance W/O going overboard as this truck has checked all the box’s for me and has been trouble free.
Just posted a review for you, and everyone else. So far I’m really happy with it.
Those are really good times!
Thanks for the report. I also have a CAT6 and curious how the Stealth compares.
I’ve been happy with the CAT6. I had a throtttle control module error that threw it into limp mode but I think that issue was battery related. Couldn’t tell if there was any parasitic draw.
In my opinion, the CAT6 improves the throttle response noticeably and once past ~900 RPMs the power just builds all the way to the top. There’s still some turbo lag but significantly better than stock. Map 3 in Baja Mode is where it’s at 😉
Using the truck’s computer my stock 0-60 was 5.4. With CAT6 it was routinely 4.4. I’m at 6000 feet altitude using 91 octane.
If/when you get the chance, please share any 0-60 results!
This morning in Jacksonville, Florida sea level. Flat road. We don’t have hills. Lol. Don’t have a draggy yet. 1/2 tank of gas. 93 octane. 3600 Rpm’s. Sport mode.
Thank you. Pretty happy with it. I do miss my throttle control on the cat6 though. But for simplicity, it’s great.
I might have to go make some runs in the RHO....it has kinda cooled off here in Texas but the air is still heavy.
So are those times better than what you got in the Cat6?
Yeah, but before I went in for service, I never removed the wiring under the dash...just unhooked the OBD port and tucked it.
I should have done that with my 2025 Rebel. Do you leave the wiring in engine bay also? Just make it look normal? Just trying to be faster. lol
I had the cat 6 on my Rebel. So no. My buddy has a cat6 on his RHO and a AFE track series CAI. his best time is a 3.7 on the truck draggy and that was a 3.9 on his draggy. So my guess is that this will be very comparable. All I have is a AWE Catback.
Same here.
More or less, I used to remove the wiring(not the one that goes into the cab) but since its low paid people changing the oil...the wont notice it. But you still have to disconnect the jumpers and put the originals back together.
Thank you. Will probably do that next time.
I have the stealth. I get about 4.3 in 0-60
Are you launching? I’m just learning how to do It. I did 3600 rpm’s and sport mode. 1/2 tank of gas. I’m sure I can improve my time with less weight. 0-60 4.0. Only other mods I have are the AWE Catback and lighter rims. Enkei 18x9 0 offset black rims. They weigh 23.8lbs. I do have Eibach springs front and back. 1.6” and 1.5”. But thats it.
Great times! Thanks for sharing your experience. I have a CAT6 and love it, but Stealth's simplicity has me interested.
You mentioned you miss the throttle control of the CAT6. Would you mind elaborating? I’m interested in your thoughts on throttle response between the two tuners.
Thanks in advance!
Did he say if you run 87? I didn’t think the high output could run 87? Can it?
Thanks in advance!
I think @Craigt55 may have missed your question about comparing it to Cat6 throttle response. I know he read your post. He gave it a like.
Thanks in advance!infeel
Thanks in advance!
I feel like the stealth throttle repose seems pretty smooth. When I hit the gas it’s like the turbos are ready to go at a moments notice. The Cat6 throttle feels like it’s a little more sensitive, and it’s lightning fast as well. Nice thing is you can control that sensitive throttle, and make it feel a little more smoother like the Stealth. Hope this helps.
I thought I replied. lol. Maybe I forgot to hit send.
Rough Country Light Bar with DRL install. What did you do to your RHO Today? 2025 Ram 1500 RHO tonneau cover best value option for off road use? Tonno Pro Lo Roll Picking up What did you do to your RHO Today? This was funny but not RHO related.
