Are you tied in directly to the battery or are you using one of the aux switches for power on the compressor, I plan to be installing the compressor this weekend as I already have the airbags installed and have been using them.
I in effect tied directly into the battery. What I mean by that is that I pulled the fuse box cover off that is right next to the battery and tied into one of the feeder lugs. I used a meter and they’re all hot so I chose one with the larger cable size. I do still need to tie in the ignition feed to one of the ignition on circuits so at the moment, I’ve pulled the fuse so it won’t run at all until I get that done. I’d say the one somewhat different thing I did was to buy some braided wire loom from O’Reilly’s and I ran the wires in that up to the battery fuse block.
A local customer has been running our downpipes since September on their RHO with the OEM exhaust. They have since asked me to make them a new exhaust system, which I'm working when time allows. They are on the forum but not very active.
Here's a few clips of their truck.
Where can we purchase these ???????????? They sound great !!
Nothing exciting...Removed the Ram and 4x4 badges in prep for a professional paint correction/ceramic coating.
We know who else has money around here.
What exactly is it that they do for " paint correction" ??? I'm confused :ROFLMAO:
Been a busy week. Did most of this all this week, had the dealer do a few things too since it was going for service.
My list of done this weekish"
Installed Rough Country Cap (and the 3rd brake light wiring!!)
Installed cabinets on both sides of cap
Installed roof rack on Cap
Installed solar on Roof Rack
Installed Starlink on Roof Rack
Installed Bluetti charge controller and battery
Installed air filter prefilter
Installed rear diff skid plate
Installed rear shock skids
Installed vent fan in cap to create positive pressure system to prevent dust and another vent that can be opened and closed for venting.
Installed bed molle
Installed rear view mirror camera relocate to back of cap
Installed extra gas cans for trip
Installed track boards for trip
Installed bulletpoint mounts on dash.
probably a few other things too, that I am forgetting.
Still more to do, but have the majority of things that needed to get done before this first trip, are done.
Tomorrow, will do whatever I can for what is left, then pack and loadout on Sunday for trip starting 5am Monday morning.
Its funny how organized I thought I was doing with wiring, then when all done It looks like a mess to me. Ugh Oh well, everything is solid and works, I can clean up some of the wire in the future.
Installed bed molle
View attachment 30306View attachment 30305
Busy beaver!
Looks great! Did you have any issues with your side to side clearance? Mine was too short on one side. I could only get one side to actually lock. Didn't matter how I adjusted it. I ened up having to shim both rails 1/8 if an inch with aluminum flat bar in order to get it to lock down on both sides.
No issues what so ever! Washed the truck yesterday and there was no water inside after either!
I just noticed that yours is the regular side rails. I got the cover with the t- slot rails. Must be something different with thoes that made mine so i had to shim the rails. After that though same thing no water inside my truck either.
Put Lamin-x yellow film on my fog lights. Got flush mount rear stake pocket hole covers. Put black silicone plugs in all the holes inside the bed of the truck. Installed the ark splash guards. Definitely a necessity on thoes. Im not a fan of splash guards in general but there was so much crap getting thrown up on the sides of the truck and I have the heavily textured mopar running boards that holds all the dirt and grime. The arks blend very well with the body lines of the truck.
How does the Lamin-x match with the hood and marker lights?
I went with yellow. I've always had yellow fogs. Like the look and the benefit. You can buy different colors. They have an amber if you want to match the hood lights. its definitely a quality product. Thick. easy to work with. Very transparent.
I have a a scheduled date! What did you do to your RHO Today? TaZer DT for RHO What did you do to your RHO Today? False Indication of Oil Level Rise & Oil Analysis Results 2027 RAM RHO Order/Schedule/Build Thread
