I went with yellow. I've always had yellow fogs. Like the look and the benefit. You can buy different colors. They have an amber if you want to match the hood lights. its definitely a quality product. Thick. easy to work with. Very transparent.
Did the have it custom cut for our trucks, I see they have a bunch of vehicle specific but didn’t come across the RHO
Did you remove your fogs to install and get a nice clean wrap?
I just bought 2 sheets of it. One sheet should do 3 fogs so you will have plenty extra if you mess up. But its very forgiving. Cut a rough cut out of the light itself. I didn't remove the lights. Applied it wet and slipped it into place. I've tinted windows many times. This was similar but easier.
Put Lamin-x yellow film on my fog lights. Got flush mount rear stake pocket hole covers. Put black silicone plugs in all the holes inside the bed of the truck. Installed the ark splash guards. Definitely a necessity on thoes. Im not a fan of splash guards in general but there was so much crap getting thrown up on the sides of the truck and I have the heavily textured mopar running boards that holds all the dirt and grime. The arks blend very well with the body lines of the truck.
could you please give me the link for those silicone plugs, mine don't sit flush.
Yeah I can't get the windshield either. I didn't expect to be able to get the roof but it would be nice to be able to clean the bugs off the windshield without a step stool
Open the door and stand on the running board (if equipped) usually makes cleaning the windshield possible without a stool.
Are you referring to the stake pocket covers on Top of the bed rail?
Fresh out the tint shop today, 15% all side windows and 5% on the back rear glass. Also added the RealTruck Retrax RetraxONE MX Retractable Truck Bed Cover
I have the t slots and had that issue too. I didnt need to shim just needed to loosen clamps a bit and adjust the lock nuts. Finally found the sweet spot and have been golden since
This^^. Same thing on my MX4 with the T slots. Looked like garbage at first until I loosened everything up, pushed down on the T slots, and retightened. Looks perfect now.
I felt like the passenger seat hdmi/glove box screen would never really be utilized…so I ordered a $29 Roku Stick, connected it and set it up and it works perfectly! No need to go crazy with 4k or HDR as the screen actually only plays in 720p.
The result is a fully functional Roku with remote. The Roku supports Bluetooth, so I connected a JBL speaker just to make sure it worked and it is up and running.
The only snag in the setup was the part where Roku asked for tv manufacturer for being able to control the set. Obviously this isn’t a tv, so I selected Harman Kardon and answered as though the tv was working with the remote.
I singed in to YouTube TV, Prime, Netflix, and Disney plus. All worked flawlessly with the Ram’s WiFi.
Added Eibach Pro Springs. Going to stay on the stock tires until I wear them out.
So dope.
Changed my rear differential fluid last night at 6k miles. Surprised on how black and shiny metallic the oil was.
Also the fill plug I probably could have taken out by hand by how loose it was in there.
But all topped off now with good clean oil and tightened up.
Changed my rear differential fluid last night at 6k miles. Surprised on how black and shiny it oil was.
I’m at just over 5k and need to get this done.
Any thoughts on doing transfer case or front diff as well? I’ve read around and everything I’ve seen seems mixed on what fluids to replace over the first few thousand miles. Rear diff and engine oil aside.
Or dont,if you like putting out your personal info on the internet, that's all you. Why dont you post your ss# and checking account while your at it
My plates are all over the internet....this isnt your fathers Oldsmobile
This also is no longer my father's america,scammers and grifters everywhere brother
I have a a scheduled date! What did you do to your RHO Today? TaZer DT for RHO What did you do to your RHO Today? False Indication of Oil Level Rise & Oil Analysis Results 2027 RAM RHO Order/Schedule/Build Thread
