This is the only thing holding me back. I may ask the dealer what they'd charge me.
I kind of wish I would have gone that route. I do have some mechanical ability but those fricking clips on the side molding sucked (hard to see/find). I put extra painters tape on and still marred the plastic trying to get them off. It isn't too noticeable when everything is put back together but I know it is there.
Can these be aimed up or down? Or do they just mount on.
Did a little cleaning under the hood, while the kids got ready for school..
...wife says I'm obsessed...
...she's not wrong.
I just finished installing my M&R 23" Pro Lights. It went like expected, a major pain in the ass! Getting the side panel clips off, to access the three bolts underneath each of them, was a nightmare for me. Additionally, I broke the plastic push pin holder on the drivers side (that was the first one I pulled). It is taped down for now while I look for the part or figure out a way to rig it. Several of the push pins also didn't want to go back in correctly. I'm going to order new push pins. Now that I'm done I like the way they look. If I had to do it over I would have taken it to someone or skipped installing them altogether.
Tomorrow I'm doing the rear backup lights. Should be a lot easier although M&R didn't label the mounting brackets. I'll figure it out by watching the video.
Wow, sorry you had so much trouble! I had none of that thankfully. Everything eased off nothing broken. I had a little delay getting to those hidden fender screws but once I figured out the first one the others were off in 2 minutes. Did you use a trim removal tool to pry up the push pins?
...she's not wrong.
Looks good!
Care to share your approach to cleaning under the hood?
Bring it. But I'm in LA (that's lower Alabama 😂)
Beautiful place! If you decide to tackle it yourself I'd be happy to consult with you to help you out
Looks good!
Chemical Guys Barebones Undercarriage Spray
I spray it on, then wipe down the areas I can reach. The rest of the areas, you can let it spread out and do its own thing. For the undercarriage, I spray it on, wipe down the fender liners, and I'm done. It evens itself out very well.
Works great under the hood, too.
After you do it once, the dirt sticks to the Barebones, but washes right off. I reapply after three or four washes.
It's excellent on the bumpers and exterior plastic trim, but BE WARNED: Barebones is heavy & thick. When coating exterior plastics and bumpers, I spray it on a microfiber towel, then wipe down most areas. It might be too heavy for some folks' liking...
It's purple in the bottle and has a Jolly Rancher Grape smell to it.
Thanks. Yes, I used a trim removal tool for the push pins. I took a quick look at the broken push pin holder again today while installing my reverse lights from M&R. I'm definitely going to need a new bracket. Sucks for me, but that's the way it goes sometimes.
Thanks Nick 797, finally snapped a photo of these wheels. I like the look of these over my methods definitely
Husky Liners® Truck Trail Armor Rocker Panel Kit What did you do to your RHO Today? RAM 1500 RHO 40in LED Light Bar PRO Easy Install INTEREST CHECK: Molle Bed panels Need help with factory ride  hight sensors … *** Post New RHO Photos Here ***
