Place the phone upside down (cameras down & facing the pad) on the driver’s side charging pad. That’s how I got it to work.Just got my truck back from service, and they completed the digital key TSB, which fried the digital key control module. That was replaced and now my app shows digital key! The dealership programmed a new key card for me, so that is good to go.
However, I tried to connect my iPhone 16 Pro and it continues to fail to pair. I’ll have to verify there’s not a compatibility issue and figure out if there’s some magic pairing sequence I can try to get this to function…
One step closerView attachment 35863
Which tab number is it? There’s a few apparentlyJust got my truck back from service, and they completed the digital key TSB, which fried the digital key control module. That was replaced and now my app shows digital key! The dealership programmed a new key card for me, so that is good to go.
Mine works just like the fob. No need to fumble with phone. Only time it doesn’t is if I have proximity off and then you gotta treat it like tap to pay on the door handle and the charging pad to start.So I may have a setting wrong. If not, the phone as key thing is not as convenient for me. But maybe someone here knows of settings that need to be adjusted that I dont.
I like that when I walk up to the truck and grab the door handle it unlocks, I like that when I walk away and touch the handle on the square it locks.
With my phone, that feature doesnt seem to work. Every time I have to get my phone out of my pocket, open the app, select unlock on the app, or lock on the app walking away. Instead of just walking up to the truck and grabbing the handle.
This is just not that convenient and the phone as a key thing will just be used as a backup, in case of lost key etc. in most cases.
I dont drive the truck every day, so maybe its more about the app being closed or put to sleep between drives, or maybe there is a setting to make this work better, but if not I will just continue to use my key fob most of the time.
Hmm, I will look at that. You are talking about the proximity setting in Uconnect settings, not something in the phone correct?Mine works just like the fob. No need to fumble with phone. Only time it doesn’t is if I have proximity off and then you gotta treat it like tap to pay on the door handle and the charging pad to start.
On iPhone, you open the key in your wallet, top right corner has a small “i” logo. You click it and there’s a “passive entry” setting that needs to be on for it to work as the normal fob does.Hmm, I will look at that. You are talking about the proximity setting in Uconnect settings, not something in the phone correct?
I have android, but that option is there. Unfortunately, it is already turned on, so that is not what is causing it to not work when I walk up to truck. I havent experimented with it enough. I have just been using it as a back up, at this point, or at times when you are outside and need to get in truck, go somewhere and dont want to run inside to get the keys.On iPhone, you open the key in your wallet, top right corner has a small “i” logo. You click it and there’s a “passive entry” setting that needs to be on for it to work as the normal fob does.
I have a 2025 Limited and had TSB 08 340 25 applied to my vehicle. It took about 3 hours. There are a lot of updates.No digital key for me on my MY25. Per Stellantis email after emailing Tim and a few other a few months back, Stellantis rep confirmed I needed a TSB update .
Took it to my nearby dealer and the incompetent folks there could not figure it out what TSB update my truck needed (this after showing them the email from Stellantis person).
If anyone has any guidance here or a nearby dealer in the SoCal area that’s competent enough to perform this update, please do share .
My truck has never seen an over the air update since I took delivery on Jan 25
After watching this thread for almost a year and finally realizing that my truck wasn’t going to automatically fix itself, I decided to tell my story. I purchased a 25 Tungsten a year ago. The truck was built in 3/25. I was told at the dealer that my digital key should be available in about a week and I drove the truck 360 miles home. I flew to a neighboring state due to bs dealer tactics where I live.
I patiently waited checking my RAM app for the digital key tile to magically appear. I kept getting in my truck hoping by that UConnect would tell me that my truck received an update. I continued paying my monthly UConnect fee. Nothing ever changed.
Finally, about three months ago , I decided to send a few emails from the information in these threads. About six weeks ago, I received a phone call from Stellantis and they acknowledged that my truck should have the digital key and that my issue would be ‘escalated’. I was given a case manager who called and they said that their technician would be working on my case. Since then, I’ve received a few emails to let me know that they are still working on my case but I haven’t been given a date to take my car to the dealer or when I can expect some type of resolution. Meanwhile, I’ve had the car for over a year now with an advertised feature that I don’t have. If someone starts a lawsuit, count me in.
My digital key finally works!
I’ve tried sending ViN to Ram Cares, tried emails to the individuals above, tried a case manager, waited for OTA, and even tried to have a dealer look into this. None of that worked for my MY25.
Finally I got ahold of this TSB and shared it with my dealer on my last visit. They pushed the update and it fried a module. They replaced the module, installed the updates, and the digital key is finally available. They even gave me a new key card.
I finally got it connected to my phone. So far. I find the key more practical since I can use it with passive entry, but I have verified the phone is functional for entering and starting the vehicle with a tap…. So this will probably be a backup feature for me after all.
