Roar Pedal
Roar Pedal nothing to worry about when getting service ..they won't know it's there and won't throw any codes. All it's doing is adjusting the pedal sensitivity, nothing ECU or fueling related.
For sure, that's the conclusion I came to as well.
so did installing this eliminate the 1-2 second delay from the throttle when dropping the hammer on that 25? curious becuz its bad and its not just turbo lag. Thanks Mikey
What kind of difference does this make when in the standard drive mode? I drive in sport most of the time for better performance, but when commuting long distances, I stay in standard.
Mine is on the snail mail express. Ordered the 13th and still don't have. Wasn't planning to install right away, but it would be nice to have by now. ๐Ÿ˜•
I got mine in works awesome but I did get a check engine light. Did anyone get that and how did it clear.
Makes a world of difference. No lag whatsoever. Instant, responsive throttle. Completely adjustable and itโ€™s get quite โ€œsportyโ€ in sport mode. I have the Peddle Commander but theyโ€™re all pretty much the same
It's a big difference. Not to mention, if you're commuting a long distance or just going on a nice, easy Sunday drive- you can adjust it on the fly very quickly. For this reason, I recommend spending the extra money to get the permanent display. It looks cool too, it has a nice crisp LED screen.
I truly believe once you get it, you'll realize that you can't live without it. Especially for spirited driving. that's where it really shines. Theres zero reason to have to floor it to get some power like the OEM mapping makes you. I'm used to sensitive throttles in a motorcycle/sports cars and this made me feel right at home.
Even though it doesn't technically add power, it definitely makes it feel that way on the butt dyne.
Yes, all lag gone.
Make sure you you follow the install instructions to the letter!! You don't want to get a CEL. I left my door open for 30 mins before I started...I also did not touch the door handle or bring the key near the truck. You do NOT want to wake the truck.
On Auto you have to get more aggressive with the pedal settings like Sport+ or Race...on the RHO Sport Drive Mode, you can run the pedal in regular Sport 6 and it feels great.
Yes, all lag gone.
Yea I left the key in my pocket so got the damn cel. Anyone know how to clear it? I unhooked the negative terminals for 1 hr on both batteries, but still showing
Ok update if you mess it up and get a CEL. Undo your negative terminals on both batteries and then unplug the unit. Wait 10 mins and plug the unit back into the pedal and then connect your batteries. Clears the code.
If you don't get the screen for on the fly adjustment, does the app connect quickly to change settings or is it a longer process?
It connects fast... absolutely do NOT change the setting while on the throttle. Wait until you stop fully with foot off gas. Also, don't forget to do the pedal position learn procedure first before driving.
Whatโ€™s the pedal position learn procedure? I have mine on the way as well and canโ€™t install it until I get the truck back from the dealer
It explains how to do it in the instructions...so the Roar can learn the entire travel length of the pedal.
Finally got mine installed last night and completed the learn procedure. First drive to the office this morning has me smiling. Running in Sport+ 5 and it is a huge improvement in auto mode compared to stock. Way more responsive than the truck's stock sport mode without the RP.
Yes. Two different products, I get that, but doesnโ€™t a jb4 tune affect throttle response as well. Are they people that run both the jb4 tune and roar pedal at the same time?
JB4 itself does not have pedal adjustments. Burger Tuning does offer a separate pedal controller product though. The Cat6, on the otherhand, does have the pedal adjustment feature built into it. I wouldn't know, but I think you can run roar pedal and JB4 together if that interests you.
2,000,000 th Ram built - Somebodys RHO got built finally... 2025 RHO Just want to say Eibach Pro-Lift Kit Installed YOUTUBE / NEFLIX   on your rho screen Custom Plates
