Added K&N Cold Air Intake and MagnaFlow xMOD exhaust.
K&N intake is night and day from stock. Not only did I feel a more pronounced 'boost' from the turbos when I hit the pedal, the sound it makes as it sucks air in is bad ass and quite noticeable. Not to mention it's a pull off, hose down, oil and replace filter.
The MagnaFlow xMod @MagnaFlow exhaust has been a great add. It comes with 3 different muffler module options:
"Smooth and Elegant" - which is a larger 'muffler' with the No Drone Technology (NDT) module strapped on top.
"xTreme Delete + NDT" - more of a straight pipe with the NDT module strapped on top.
"xTreme Delete" - basically a straight pipe, no NDT
I bought it and had it installed at my local CDJR dealership and listened to all three. The Smooth and Elegant was an upgrade from stock, but not enough to warrant the cost of the new exhaust - so that module is in storage. The xTreme Delete, which is basically a straight pipe, is crazy loud. Like everyone in the neighborhood knows you started your truck loud. Which, is not necessarily a bad thing :) ...I went with the xTreme Delete + NDT. It's a perfect blend of that TRX rumble when you start it and when you hit it hard, but with some dampening at cruising speeds. Now, I still get some drone at about 2,000 rpms in 8th gear (+/- 70mph +), but it's worth it.
I had it in that configuration for about 8 months until I said - F - it, let's go straight pipe. I worked with my son to change out the modules and took us about 30 minutes to do both. As I said above - the xTreme Delete is unapologetically loud. Yes, it's a bit much when I cold start it or get on it, but the amount of heads the exhaust turns is awesome. Well worth any drone I get at 70 mph. :)
Next up? Most likley the DiabloSport Cat6 - but still running my due diligence on that for the long term.
I have the same setup on mine. Love everything about it. I did add 37s and Eibach leveling kit...any possible performance gains I could have are gone by now Im sure...but 100% worth the look.
I recently purchased the Openroad retractable tonneau cover for my 2026 RHO, I was looking at the Rough Country hard rollup, the same as what I have on my 2012 RAM 2500, but for the price of the Openroad, I couldn't pass on it, it was only $665 to the door, the tonneau went on pretty easy and not as heavy as the Rough Country, it is pretty solid once you get it on and install the brackets, fitment to the tail gate is snug but able to close it, I haven't water tested it yet but I still need to do some slight adjustments to it but all in all, it's a win with this at a fraction of the cost.
Got a wheel alignment and “Active Damper ride height calibration” at the dealership after I completed the Eibach 1.6” installation.
The calibration seems to have it damped more, felt looser before, but that’s probably in my head.
The wheel alignment left me with a crooked steering wheel, so not the most confidence inspiring. It was perfect before, should have left well enough alone.
Coated the front-end with fucking love bugs! 🤬
Man I hate those things. I was at church n killing every couple I could. This lady said it attracts them if you kill them.
Me..less to repopulate.
Thanks!!
I cleaned the front and windshield before going to Jasper Tx, I spent nearly an hour getting those damn things off when I got home, they are bad here in Louisiana, I don't let them linger to long otherwise they will etch the clear, I do need to PPF the front end and mirrors.
What part of Louisiana? I'm near Shreveport. I have PPF on my truck, but they still stick to it pretty good. I can clean them off the truck easily enough, I'm more worried about the radiator. I'm thinking ahead to how best to clean them out of it when they are finally gone. Somebody told me to use a can of foaming A/C coil cleaner.
I live between Rosepine and Deridder, Wash Chem 50 or 100 (Amazon) diluted in a spray bottle or Suds lab detail spray from Walmart does a good job of getting off the bugs, that's something I need to clean is behind the grill which should be fun.
Use a clothes dryer sheet.
I’m from kenner. Try bugslide. I
Removed the pedal commander I installed like 3-4 weeks ago. It had been fine for a while. Then this morning running errands all of a sudden the dash and info are dim and don’t respond to steering wheel controls. Digital rear view was also off. When I’d put on a blinker it was giving me a message that the tail lights weren’t working even though I verified they were.
Figured it was that (only recent addition) or the batteries dying. Removed the PC and checked the battery voltage (12.6 on both). After removal it fired right up and everything was back to normal. No codes just strange behavior. At least it was only $70 off a member here instead of $220 or whatever they want for it.
Got the truck clean, now to clean the wife’s.
Trying to decide what wheels to go with.. between these two. Anyone have a Serrano Green with silver or gunmetal wheels for a reference? Been In between for weeks!
G
Gunmetal
Bronze would look sick on serrano.
Silver
Installed a set of smoked AlphaRex Luxx tail lights with their LED conversion harness. Believe these are relatively new for the 6th gen Ram as I couldn’t find much about them. So far so good with no errors or check engine lights. Blind spot monitoring also still working. Hopefully they hold up well…will report any updates if that changes. Very easy install. Before and after pics.
Installed the Hellwig rear sway bar this morning. Immediately noticeable. Truck feels much better on the road and way flatter in corners. Now I have to install the front. Likely next week. Have to spend time with my two wheeled girls also. Thank you again @Nick797
Those are the ugliest taillights I've ever seen on a vehicle.
1950 miles clocked driving my RHO home from MD. Ram coupon? *** Post New RHO Photos Here *** Quick Spool Turbo for Hurricane coming? 2026 RHO Blue Forged Metallic What did you do to your RHO Today?
