The oe valves are there for drone no other reason. Once you remove the valves you are chasing drone.
This is all very interesting. Can you clarify why/how the OE valves address drone? I can’t wrap my head around the science behind this.
I can see how the OE valves might contribute to the bwaaaps (or wet farts as some call them) on gear shifts as they’re likely momentarily closing and then fully opening during gear shifts. Even if that’s not the intended purpose of the OE valves, it (arguably) sounds like that’s what’s happening.
I can say that with my MRT Trail Rated exhaust and my OE valves removed I don’t get any highway drone at all. There’s a very slight drone in the low 2K range with mild acceleration which was annoying in the 1st 1K miles or so, but even that has diminished.
Thanks for the detailed posts, very informative.
The bigger the hole, the louder she goes!
wet fart sounds are from timing and fuel. retard the timing and add fuel during shifts. viola burbles..
Side note: this is why they are melting cats.
  • Like
Reactions: rpr
download a db meter or spectrum analyzer on your phone, lots of free versions out there. Then go cruise at your drone RPM and get a snapshot. I can help you design a resonator to fix your drone.
My vehicle doesn't have drone but didn't before resonators either... The oe valves are there for drone no other reason. Once you remove the valves you are chasing drone.
Mufflers in general attenuate all frequencies but do a better job on the higher end of the range. Sub 100hz you're going to have to have chambered mufflers to get rid of it and that is no bueno for flow.
I've run 36" long 7" diameter straight through mufflers trying to eliminate drone... Doesn't work.. I've been deep down this road before on multiple platforms.
"We" really need to understand how loud your drone is to address it properly.
Can you tell from the screenshot where the peaks of the frequencies are from what I could tell while driving it’s all lower frequencies.
Can you change the settings so its not in large blocks like that.
Also what us the db on the left
I don’t like this app , which do you use ? I’ll download it and do another run.
I deleted the app so I don’t have the last files but this is a better picture.
In
that’s a nasty peak
A helmholtz resonator will dial that way down
I would put them back by the spare tire because of packaging and exhaust gas temperatures are much lower effecting the speed of sound.
You need a 4” x 10.75” pipe / chamber capped off on one end and a 2” elbow on the other that connects to the tail pipe section that has a 5” CLR
Can you make them for me ? Or know anyone who can ?
If anyone in California wants a custom MBRP exhaust, let me know. I picked up and installed the stock exhaust today. It’s very nice to have quiet. Cold starts again.
You sir are a better neighbor than me. I back the truck up to the garage door just to try and make the cold starts louder
  • Haha
Reactions: rpr
lol that’s hilarious my neighbors are far and I don’t care much about them. The issue is I have a 5 and 2 year old and I would prefer not to wake them early and start my wife’s day at 5am. It would ruin my day when I get home hahah.
I have 2 five year olds and a 2 year old. Fortunately for me they all sleep like rocks. I wish my ex wife was here. I'd love to wake her up every chance I got. She's a demon
But all my neighbors are pretty chill. Only have one that's a problem. His name is Lauren and he drives a Tesla. I'll let you do the math
But all my neighbors are pretty chill. Over have one that's a problem. His name is Lauren and he drives a Tesla. I'll let you do the math
That’s amazing if my kids hear my truck they come crying saying dad you can’t go to work hahaah
So are you running full stock with psp down pipes? Or did you add resonators also?
Full stock with PSP Downpipes. I have two sets of Stainless Bros resonators and mufflers coming in Friday I might add.
Dustin did say that it was all a little too loud without the resonators. I know he added a set of resonators to his and it brought it down about 4 or 5 dB then I guess the second said he added back by the spare tire brought it down to similar to stock again just deeper
To be honest with you it’s seems super quite right now. I haven’t drove it yet only cold start because I can hear a leak at the downpipes connections. It could also be quite because the stock exhaust I got was only on for a couple hundred miles and it needs to break in. I’ll definitely add one set to hopefully deepen the tone but it seems quiet enough already.
Just curious, Did you get a decibel reading at its loudest with the aftermarket exhaust and with the factory with the pipes?
I thought in all the videos on youtube that stock with downpipes sounded the best.
No way to ship the mbrp? Guessing it would be a pain without the original packaging and a small fortune.
If you get your leak fixed post up a cold start if you don't mind, and glad you got settled on a good noise level.
Audio upgrade ideas? M&R Light Bar Install Question What did you do to your RHO Today? CNC vinyl *** Post New RHO Photos Here *** Order your RHO from Jim Glover CDJRF! Up to $10,000 + off MSRP
