- Nov 9, 2023
- 1,266
- Media
- 34
- 2,220
- Location
- Feasterville, PA
- 2025 Ram RHO, 2022 Ram 2500
- Current Ride #2
- 2014 Subaru BRZ LS Swap, 2006 C6 Z06
if you ever have a chance, check with an 18" vossen!here is an 18x9 Weld Ledge. Thinking this should be good with 18s for sure mounted up.
Vossen and the Enkei have the most amount of clearance for popular 18s on these trucks. Right now I only have 20 inch vossens here.if you ever have a chance, check with an 18" vossen!
I'm gonna work on pad stuff in the background here shortly!View attachment 17868
Mine just arrived as well! Initial impression on fit/finish is i'm pleasantly surprised - they feel very high quality. My only concern is that the pads appear quite aggressive, so i'm hoping they aren't super loud and dusty - but we shall see. 2nd pic is a factory replacement EBC pad on the right for comparison.
Put me first on the list for some that are low dust and no squealI'm gonna work on pad stuff in the background here shortly!
Pardon my ignorance, but genuine question:View attachment 17868
It appears to me the surface area of the big brake kits pads are not much larger than the OEM size at all, maybe a guess of ~10% more at most?
I was imagining there would be a much bigger difference. I (potentially mistakenly) thought this was the biggest factor in why big brake kits are more effective.
Do the extra 2 pistons make an additional difference? Are the rotors themselves bigger? I'm assuming the pad sizes are identical to the higher priced kits as well, so I guess this question isn't specifically referencing this kit- but just big brakes in general.
Absolutely notWill 17's fit with these? That would get me on board
Gorgeous!Please don't argue about rotor direction, Just a quick test fit.
They unfortunately do not clear the Enkei RPT1's :/ The Weld Ledge clears just fine as well as several other wheels I tried that we had here. Going to put my thinking cap on here.
Also working with EBC on pad information, initially the dimensions were close to a R35 GTR but they are just slightly different.
Did you try stock wheels? If you posted already sorry, I didn't see your post.Please don't argue about rotor direction, Just a quick test fit.
What is the stock rotor diameter? I wasn't clear if these are bigger brakes (rotors) or just more pistons in the caliper.Got my kit here as of 5 minutes ago.
First round of info
Rotor is 14.8 Inches weighs 24.1
Center hat is aluminum
Brackets are steel
Caliper weighs 12.4 pounds
More to come
Stock Rotor 32 lbs
Stock Caliper with Pads 25
I did not, I sold mine unfortunately.Did you try stock wheels? If you posted already sorry, I didn't see your post.
I need to swap to a different wheel to be able to run these for right now.First impressions with actual braking p
