Level kit best option
Best level option
  • Spring with factory strut
    Votes: 22 91.7%
  • Spacer below
    Votes: 1 4.2%
  • Spacer above
    Votes: 1 4.2%
  • Total voters
    24
New RHO owner here - 2 weeks in today!
As a previous Raptor owner, I must say.. This thing rips! I had to do a lot of upgrades on the Raptor to get it to run like this thing does and I haven't even seen the full potential yet, as I'm waiting for it to break in properly. So far, I LOVE IT!
I had the Eibachs on the Raptor as I didn't feel like compressing the coil with collars was the correct way of doing it. I know a lot have on both the Raptor and TRX/RHO with no issues, but I still felt better using a longer coil. (personal opinion I suppose)
With that said, I'm planning on replacing the front coils on the new RHO with the Eibachs as well - unless someone can logically talk me out of it lol
I do have some questions, as I haven't seen anyone mention it on here yet.
  • I've seen some rumble about these truck pulling to the right a bit and I "think" I seen something about a TSB on it as well. I did do a search and noticed that the TSB was isolated to early builds (prior to April 2025) - I did notice a very slight drifting to the right (may have been the road, again, I've only had it 2 weeks / 800 miles) - should I get this taken care of prior to installing the springs (I'm assuming the answer is yes?)
  • If the answer is "yes" to having the TSB taken care of prior to installing the Eibachs, should I have the front end re-aligned after installing the Eibach coils too?
  • Last question... Who has the best price on the Eibach springs ** I'm only doing the front **
Thanks for the input!
Get the eibachs asap! Truck rides so much better. 1.6” lift is perfect.
I did the TSB for the pull to the right after the springs, truck drives perfectly straight now.
I bought direct from Eibach, $300 or so.
Don’t hesitate. And don’t forget a Diablo CAT6. I could never go back to stock now. It’s a massive upgrade. Don’t skip it trust me. It’s a totally different truck.
Coils are on the way from Eibach! $399.00 delivered (y)
Looking into the Diablo CAT6 now!
Thanks for the info and advise! (y)
Are any adjustments needed for the Bilstein struts? Does it ride bouncy, and can you still change the suspension to sport to tighten down a bit? Did you need the height sensor kit?
Takes away the bouncy ride of stock! Soooo much better. The way it should have came from the factory. I leave it in street mode and it’s perfect. I also didn’t need any height sensor kit. No issues after 1500 miles on the kit. It’s solid !
Off topic, but I wanted a Hydro Blue! There was zero to be found at the dealers around here... Beautiful truck!
A few of us perch or spring with 2 or more inches of lift needed the height sensor kit , I wouldn't have known from the few full throttle launches what was wrong but after changing the height links every thing feels better when accellerating.
ME TOO !!!!!! I even tried to have the color I ordered changed to Hydro the day after I ordered it up until mine was delivered !! No dice.:(. I looked all over the United States and there was none to trade either ! Very few and far between !!
Me 3
Thank you. I've always loved that color too. That was the first color I saw on the TRX in person—dream truck for me.
Me 3
:ROFLMAO: That was the first color I saw on an RHO !!!:LOL::ROFLMAO:
Weld Ledge 18x9 -12 Gun Metal Finish In stock! What did you do to your RHO Today? Rough Country Tri Fold Cover In Stock Need Your Bed Cover Experiences RHO & Coffee @ 797? Grille Emblem Replaced/ Color Matched
