Ram RHO Aftermarket Wheel Specs and Tire Pictures [Size/Offset]
Very nice. My RHO definitely drove better than my Mega cab, which was expected. Since you had a 23 PW, how did the articulink suspension in everyday driving compare to the RHO?
For daily driving the RHO is better in almost every way... Smoother, faster, better MPG, more comfortable etc. Suspension compared head to head daily I'd say the same - the RHO handles bumps, railroad track, potholes and curves much better. Just did the rear anti sway bar and that made a notable difference in highway lane change footing and rounding curves the body roll is less. Worthwhile upgrade for sure.
What sway bar did you install in the back?
The Hellwig - very happy with it. Feels more sure footed and planted turning and going around curves. It's no sports car but with the smooth accel this truck has, coupling that with the sway bar tightening up the rear end is a must do. Under $500 for the notable result makes it easy.
Install is pretty simple just follow the instructions. Mine came missing the jam nuts so had to get a couple and redo that part of the install. There are 3 settings on the bar... I went with the middle but am considering moving it back one to the tightest/firmer setting. Wouldn't bother with the least correction/first hole as I'd bet it's barely noticeable.
For the look and a *slight* improvement in the same area, I plan to trim 1/2 coil off the top (softer side of the progressive spring) in the rear. Should bring the rear down near an inch and "reverse level" some, leave a little aggressive truck rake, and potentially firm up a touch. Love a no/low cost modification that actually makes a difference.
If you’re saying what I think you said, I believe you have your settings backwards. To put it another way the hole at the very end of the bar is the weakest setting the one further in is the strongest setting. It’s a leverage thing.
Any thoughts on their front sway bar? Worth it or just the rear you think?
If it is built the same way as the rear sway bars on the 1500s it is Junk!...The factory rear bar is hollow and the Hellwig is a solid bar.
What are you looking to accomplish?
The factory set up is pretty awesome for off-road etc.
Where have you found fault that the factory was insufficient. Considering the purpose of the truck.
I’m waiting.
I’m waiting.
And you are still waiting....
Well @D&Sadventure above seems to think the front is much better
I didn’t cut it open, but I would be surprised if the front was hollow. If I remember right it was pretty heavy when I dropped the sway bar frame mounts to do my front springs.
I'm am basing my opinion from all the posts on the Trx forum that it is a solid underrated upgrade...I would bet the farm it is hollow.
Will a -12mm offset push the wheels out too far and make the wheel rub. Daily driver, and using stock tires for now.
Can anyone tell me if a 20x9 with 10mm offset work or would that be tucked in too far? Found a cheap set from a local guy and I have new nittos to fit them.
Stock ones are +18 and they’re definitely not stuck in too far
What did you do to your RHO Today? 2025+ RHO Owners: Curved 23" SLIM Bar for the Opening Between the Grille and Bumper For the April-May Orders. Ram Contact info RAM Coupon Knocking on wood didnt keep the gremlins away... How true are Estimated Delivery Dates once you have one?
