Yessir, $200 americanDoes the Preorder save $$?
What’s the price?
pinnaclespecialtyperformance.com
Not with the downpipes, it’s inside and loudBefore I forget, did you happen to get any dyno runs for sound?
Did you get any logs with wgdc or fuel trims? Anything funky looking?
WGDC is going to be lower. Anytime you remove restrictions it comes down as the turbos aren’t working as hard to hit target boost.Did you get any logs with wgdc or fuel trims? Anything funky looking?
Results dont lie, curious about how loud this would be with an awe exhaust though
For the WGDC, i was just curious if due to the lower restriction you were seeing big wgdc corrections and boost that was overshooting and undershooting until smoothing out. I'm sure the computer will learn and store these corrections overtime, but just my curiosity getting the best of me.WGDC is going to be lower. Anytime you remove restrictions it comes down as the turbos aren’t working as hard to hit target boost.
I’m not seeing anything funky.
AFR’s are right where they were before and of course no CEL.
Sound is subjective but I would say “loud-ish” paired with the awe.
It’s +6-9db’s on the factory exhaust so it stands to reason you’d see a similar increase.
It needs to stop raining here so i can go do more pulls but I do have baseline datalog graphs to compare the boost curve to.For the WGDC, i was just curious if due to the lower restriction you were seeing big wgdc corrections and boost that was overshooting and undershooting until smoothing out. I'm sure the computer will learn and store these corrections overtime, but just my curiosity getting the best of me.
Any chance you have a boost curve logged/graphed?
I think I sawSeems these are best paired with the JB4, they will give you the low end bump, while the tuner provides the top end hit.![]()
I'm going to put together some datalog graphs and overlay against the bottom end of my pre-dp logs below.I think I saw
On the FB post over 100 ft lbs torque gain with the under and down pipes. Maybe it was more?
Are you looking for improvements or just times?Is it possible to get some 1/4 mile times on the test vehicles to share? TIA
I wanted to compare times from what others have posted with stock trucks and trucks with tuners on them and see if the added torque from these cats get this thing moving quicker off the line.Are you looking for improvements or just times?
DA > everythingI wanted to compare times from what others have posted with stock trucks and trucks with tuners on them and see if the added torque from these cats get this thing moving quicker off the line.
I think this is probably the single best bang for the buck power upgrade. Yes power upgrade not done for sound. And yes I know the piggy backs are cheaper. To me this brings the power on much sooner. Like TRX sooner. In the low end as much as 700 RPM sooner.Solid peak gains as well as great power improvements across the RPM range. Peak torque is delivered almost 300 rpm sooner with massive bottom end gains.
Stock vehicle (red) vs the addition of PSP Fat Cat down pipes (blue).
downpipes still going strong? any idea on the release date? I'd be all over these; my biggest fear is how loud the truck will be with a full catbackDA > everything
I’m at 4500ff and DA is usually 6k and i’m running 36” mickeys on KMC’s at 110lb’s per…
So no, that isn't a good comparison.
For reference, already 4 tenths slower pre dp’s than other folks have post.
plugging away getting material for the production run.downpipes still going strong? any idea on the release date? I'd be all over these; my biggest fear is how loud the truck will be with a full catback
Are you adding the resonators to a stock system with the down pipes?plugging away getting material for the production run.
I understand the concern about it being loud. I'm actually going to install some stainless bros resonators this weekend to see what type of reduction it makes to address those concerns and to have a recommendation for folks who want to tame it down.
Current assumption is 4-5db reduction which will bring it pretty close to stock.
Looking at the AWE there is room to add said resonators as pictured below.
615-07636-0111-3" SS304 Inlet/Outlet Bullet Resonator 4
www.stainlessbros.com
