yesAre you adding the resonators to a stock system with the down pipes?
plugging away getting material for the production run.
I understand the concern about it being loud. I'm actually going to install some stainless bros resonators this weekend to see what type of reduction it makes to address those concerns and to have a recommendation for folks who want to tame it down.
Current assumption is 4-5db reduction which will bring it pretty close to stock.
Looking at the AWE there is room to add said resonators as pictured below.
615-07636-0111-3" SS304 Inlet/Outlet Bullet Resonator 4
www.stainlessbros.com
Would you say the stock system with the Downpipes is comparable to a catback with mufflers? Like the MF speq.
YesWould you say the stock system with the Downpipes is comparable to a catback with mufflers? Like the MF speq.
What DS Map and Fuel are you running for both runs on those charts?RESULSTS ARE IN!!
PSP Fat Cats make more boost everywhere!
MASSIVE MIDRANGE GAINS!!! 3K-4K rpm's with an average of 4.3 psi of increased boost!
improved bottom end as well as you are making an average of 3psi more from 2k-3k rpm's
boost curve delta follows the dyno curve really close.
Same sameWhat DS Map and Fuel are you running for both runs on those charts?
any check engine light issues with these installed?
These down pipes are still digging a hole in the back of my brain. I don’t need them, but I think I want them. I still think their hands down the best Performance gain as far as power. I just don’t want to regret it if I have some problem and they blame it on the cats Later down the road. I also want to hear what they sound like with the stock exhaust on them. Also, with the added resonators you were talking about so that it can be toned back down again. As long as the resonators don’t add back in enough restriction that it loses what it gained.
At max…look at the power produced under 4k rpm…it’s substantial.wait so it's only 15HP and 45lbft gains compared to the stock exhaust?
Anyone that you like the sound from. Zero HP or torque gains.I'm a novice at anything other than a cat-back system. But, what do you feel is the ideal cat-back to run with this?
Peak, meaning the highest amount stock vs the highest amount with fat cats.wait so it's only 15HP and 45lbft gains compared to the stock exhaust?
“MY IDEAL”I'm a novice at anything other than a cat-back system. But, what do you feel is the ideal cat-back to run with this?
