The rings aren't the DRLs, the hockey sticks are.How do you NOT have on your white drls??? Fishy
So even though you turn off drls on uconnect, the amber drls stay on?? Thats interesting.
They said that as they are able to crack more codes on this new electronic system, that they would be adding new features for free. You just have to pull the little black module out, and update firmware and reinstall.looks cool. if only it did the hood and marker lightsif they can manage to add options for those this is a buy tomorrow, thats my only true wanted feature.
thats good to know but ive learned to buy a device for what it does now not for what the maker promises in the future.They said that as they are able to crack more codes on this new electronic system, that they would be adding new features for free. You just have to pull the little black module out, and update firmware and reinstall.
Very true.thats good to know but ive learned to buy a device for what it does now not for what the maker promises in the future.
As for the white not on. In my camera they looked like they were flashing. Which they weren’t. I think I literally took a photo in between flashing somehow. Luck shot.How do you NOT have on your white drls??? Fishy
Well that's no fun!I’m a nurse in a top neuro trama unit, the seat belt chime is annoying sure but easiest way to stop it is to put your seatbelt on…. I can tell you we get a lot of unrestrained and restrained drivers on our unit and generally those wearing their seatbelts are doing a bit better than those who were not. Sure you might be just going down the street or something but most accidents happen close to home.
But wait, there's more......thats good to know but ive learned to buy a device for what it does now not for what the maker promises in the future.
How would you know if you needed an update ? Before I install. Is yours trouble free with remote start and all ?Installed yesterday...
The update fixes the light show on the headlights when you first turn on the truck and remote start but only if you use the pin setup to better secure your truck. If you have no plans to add the pin then there is no real rush to do the update. All that being said the update is super simple and takes less than 2 minutes via the webpage install.How would you know if you needed an update ? Before I install. Is yours trouble free with remote start and all ?
Im going to take a wild guess at this. My thought is that since the install was not completed the truck may have been trying to communicate with the different systems/modules to shut down/go to sleep/ update, who knows. Since it could not see or command thoes different systems it kept trying and in turn ran the batteries down. I would say leave it connected and charge the batteries. Go from there.Okay, so my friend just installed this, and having some troubles…
Started the install this morning and had to leave before getting everything connected. It did not take a minute and 35 seconds.
Got the install done. Went to start the truck and it’s completely dead. Interior lights won’t even turn on. Rechecked all connections and everything was correctly seated. Same result. Pulled the Synapze out and reset all factory connectors and the truck is still dead.
Was very cautious not to pull on any wires during the connector removals. Any other ideas?
I guess he could put a charger on the battery but that would be pretty odd since it had plenty of juice prior to install. Do we need to charge both batteries on this truck, or just the main?
Don’t have one… one of my boys blew it up.a volt meter is such an easy tool to use to see if the batteries are dead ¯\_(ツ)_/¯
