TaZer DT for RHO
Their instructions are online so you can check to see if it uses the same connector
Yeah, that would involve me looking (or remembering) what I connected the AS/S to in that same kick panel. Maybe someone has had both and can chime in - or I'll just wait until mine arrives in a few days
Is anybody else's headlight dimmer than the other? My drivers side is significantly dimmer than the one on the passenger side. The regular drls seem to be the same brightness though.
As to the question of batteries dying with the Synapze. Had zero issues with batteries. Then 12 days later my batteries are dead. Want even jump. Towed to dealer this am. Pulled off my Snyapze before it got towed. Warranty covered. As for mode. The only thing I’ve done was Amber DRL both A/S. I’ve not updated the module yet. So many updates are coming out. I figured I would just wait. I’ve seen several people on Facebook that have had batteries go bad after installing. Coincidentally, who knows with these batteries. But think I’ll wait a little bit until i reinstall. Curious if there is possibly a parasitic draw. It supposed to go to sleep 30 seconds after you turn off your truck. Time will tell.
27.0.4 is now up on their site to address the battery drain issue
Thank you. Just replaced my batteries today. Took off before it went to the dealer this am.
2WD engaged by following the new instruction sheet. Did a small burnout at a stop sign leaving the neighborhood to try it out and it definitely worked.
We can't read it lol please share
Hopefully the resolution is better.
Has anyone experienced dead batteries after install of firmware 27.04?
I’m not sure what’s up with mine. Did update. Couple hrs later truck won’t start. Tried jump starting and nothing. Only a small click from starter but engine barley turns
Wasn’t there a fear on the TRX forum it would destroy the transfer case if left in 2WD or has that been debunked?
I think I read something similar recently in a comment but I personally have no clue. I don’t think this is the same product the older TRXs used, though. I don’t intend to keep it in 2WD; just thought it was a cool feature and wanted to try it out.
Quick burnout leaving work today
You lock the axle or leave a single strip?
Left a single strip behind. It was a spur of the moment situation in a place I definitely shouldn’t be driving like an idiot. Locking the axle didn’t even cross my mind in the moment haha
What settings did you activate on your Synapze DT? I'd check the voltage of your battery. If good, then remove Synapze and disconnect battery for 15-20min, reconnect and see if issue resolves.
Not sure if yall know. They did an update just a day or two ago. It’s supposed to fix the issue that was causing people’s batteries to die on them.
Does anyone have an educated guess as to if they will put a remove or up the speed limiter option into the Synapze? Have they done this on previous platforms or versions before? What other features are on some of the other modules that you all would like to see for the RHO? I'm on the fence about getting one of these. There are some features that I like but I also don't want to pay the money in hopes of what "might" come down the line as far as features or be a "tester" for this device. Thoughts and input??
Ram RHO Graphics Installed Baja Design LP9 Bump kit First time Truck owner - RHO or Raptor? Just ordered - anyone have the 2026 Blue color with pics? AI Generated RHO Pics - POST 'EM UP!!! KW to HP
