Turbo/wastegate actuator rattle!
I pegged mine open and only cost is 4 band clamps. My GMC had them also and I had done the same on that for a bit more exhaust note and zero rattle. Can also go back to stock anytime
Where are these valves located on the RHO towards the back of exhaust or middle? I wanna do mine
Near the passenger side rear tire.
Mine has the high pitched noise at startup. Mine does not have a leak (rock solid boost pressures and vacuum). It sounds exactly like my old Subaru STI air pump that enabled on startup. I beleive it had something to do with emissions.
For those of you that have the actual "waste gate rattle", from the actuator rods themselves, , I have been able to eliminate 99% of it with springs just like the raptor guys were able to do . I experimented with spring placement, lengths, and tensions. The position, and springs in the pic are where I have the best results. The rattle on cold starts and slow/light acceleration is 100% gone. (cold start was where mine was the worst. Sounded like a broken sewing machine) I now only hear the rattle on deceleration from higher RPMS, like when you are in Baja mode and decelerate from like 4500 rpms and higher where the trans holds the gear vs upshifting, and even then the rattle is almost imperceivably.
Update on this? Still giving good results? No issues with the movement of the rod with the amount of tension you applied?
Mine is about 99% gone as well. Followed your exact setup. Could you take a picture of where this clip goes? I either knocked it off or it was never attached
I need to do this. Mine is getting so bad.
Just snapped these real quick while at work. Hope they help
Do you have a part number for the springs you used? Thinking of going your route to eliminate the waste gate rattle.
Yep, those are the ones.
I wonder if ours rattle and I don’t even notice. Probably should just do this.
Mine has the rattle as well, mostly when cold or hitting the throttle briefly in neutral. It seems to be the rear turbo actuator. I'm going to ask the dealer about it on the next oil change
Sent the pics twice but thanks to some help from TXRHO it worked here’s mine
Exhaust Options Fuel Wheel Price Drop! Post your favorite picture of your RHO Incentives Update on RHO from MARK DODGE MOPAR Edition RHO @ Mark Dodge Eibach 1.6 vs 2.7 front only
